looks like the new NVidia driver bug, try installing an older driver version (before 5000 series, they're borked since)
https://linustechtips.com/topic/1610498-gpu-temps/#findComment-16716697
34 minutes ago, helloitsme23 said:
so hardware ifno when i view it from the sensors it shows the right temps looks like i only see 29c in task manger and msi afterburner
Strange, use an app like Revo uninstaller to completely remove MSI afterburner from your system and reinstall it
Also, are you selecting the right temperature to display in MSI afterburner?
Console.WriteLine("Hello World!");
https://linustechtips.com/topic/1610498-gpu-temps/#findComment-16716698
2 hours ago, leclod said:
No selecting needed, as far as  I know.
I assumed they were using the overlay, where from memory there are multiple temps per device
Although on second thought I may be thinking of other apps
https://linustechtips.com/topic/1610498-gpu-temps/#findComment-16716820
