Hello everyone, I need help with building a new computer for myself, never done it before and honestly i'm quite scared to lmao
My budget is around 2000 USD or 7500 ILS
I live in israel and importing part and ordering parts is quite a headache
Games I plan on playing are - Marvel rivals, MH wilds, Black desert, and eventually the witcher 4 and GTA 6
Right now I have two monitors that run games at 1080p, for now it's totally fine for me but I would love to run games at 90+fps on 2k resolution when I get the right monitors
Thanks in advance for any help!
https://linustechtips.com/topic/1609874-need-help-with-building-a-new-computer/
Hey, welcome to the Forum! 🙂  Building your first system can seem quite scary indeed but its easier than you think.
Just watch some guides on Youtube.
Thats a healthy budget for a system!  Can definitely build something solid here.
I'm a bit busy right now but maybe @PDifolco@Why_Me@podkall can put a list together.
I have helped at least 60 people from LTT Forum over Discord while they built their systems, many of them were complete beginners.
If it was just quicker chatting assistance or a 4+ hour voice call, I have done it all 🙂
If you want, I can be available ( for free of course ) when you build your system so you can get quick assistance if needed.
No local e-shops? Or just bad prices overall regardless if imported or not?
that's not hard to do with your budget hopefully.
How much does Ryzen 7600/7600x CPU, B650 chipset motherboard and 2x16GB of DDR5 6000Mhz RAM cost?
GPUs
How much for RX 9070 XT, 7800 XT, 7900 XT or RTX 5070 Ti?
A PC like this could work:
https://pcpartpicker.com/list/MhvKdb
Though prices may differ, if there's room to get similar PC like this that's nice. If you can get even more, you could swap some parts for better ones.
For example 8 core 7000/9000 series Ryzen CPU instead of 6 core.
RAM with tighter timings. Slightly better motherboard.
Better NVME storage.
current PC:
PC configs I used before:
GPUs
The prices are still really bad overall I would say, and with shipping fees it gets even worse
The rtx 5070 ti, rx 9070 both go for around 1100 usd
Cheapest B650 motherboard I found was around 150 usd, same goes for the ram aswell
Ryzen 7 9700x 8 cores is 400 usd
All of these parts combined are 1800 usd and im not sure if the other components can come around 200 usd or if what I conjured even fits lol
How much for 7000 series 8 core?
Which models?
That's quite an amount, more than half entire budget on GPU.
What about last-gen cards? 7900 XT?
It's pretty decent selection, but it's still missing a lot.
You need:
  • CPU
  • CPU cooler
  • Motherboard
  • RAM
  • Storage drive
  • GPU
  • Case
  • PSU
Or if you found some, for cases there's also brands like Cooler Master, Deepcool and Antec.
Deepcool makes CPU coolers too, same with ID-COOLING.
RAM brand doesn't really matter as much as speed.
current PC:
Which models?
You need:
  • CPU
  • CPU cooler
  • Motherboard
  • RAM
  • Storage drive
  • GPU
  • Case
  • PSU
The ryzen 7 7700x is the cheapest if I got the 8 cores right, 290 usd
The motherboard model is B650M-S2H
The 7900 XT is around 965 USD which really isnt much cheaper
I do have a newer PSU I bought last year, I think it's a coolermaster 750 watt not quite sure, I got along with an SSD of 1 tera
Find something else, give me 10 examples even if it's not too much work on your side.
You save 100+ $ and lose 1-4% of performance on average.
You can check what model is it when you have time.
current PC:
I see what you mean in the GPU side of things makes sense, Ill check my PSU when I get home,
Motherboard are:
B650 mATX with many more of these with different specs
AMD B650 ATX
if itself not much Ill link them
AMD B650 ATX
doesn't tell much, but if you copy the model (B650M-S2H) that works
current PC:
Yes I get it now
So the order goes from cheapest to most expensive:
PRIME-B650M-K
PRO-B650M-A-WIFI
B650M-DS3H
B650-UD-AX
PRIME-B650M-A-II-CSM
B650M-GAMING-PLUS-WIFI
B650-GAMING-PLUS-WIFI
PRIME-B650M-A-WIFI-II
B650M-GAMING-X-AX
TUF-GAMING-B650M-E-WIFI
TUF-GAMING-B650M-PLUS
PRIME-B650-PLUS
B650-A-ELITE-AX-V2
There are more
Do you have a link to the shop you will be purchasing from.
https://www.plonter.co.il/detail.tmpl?sku=100-000000592&cart=17455289678207204
https://www.techpowerup.com/review/amd-ryzen-7-7700-non-x/
https://www.plonter.co.il/detail.tmpl?sku=100-000000597&cart=17455289678207204
https://www.techspot.com/review/2728-ryzen-7500f-vs-core-13400f/
https://www.eurogamer.net/digitalfoundry-2023-amd-ryzen-5-7500f-review
