8 minutes ago, takehi said:
hi everyone!!!
i've been planning to build a pc for quite some time and thats what i came up with.
I'll happily read any reccomendations or tips in the same price range!!!
https://pcpartpicker.com/list/PdcXZc
Welcome to the Forum!  This is a fantastic build without overspending on RGB and useless features.
The Ryzen 7700 comes with a stock cooler so you can save 34 bucks there but it will be louder than the Peerless Assassin.
I have no real complaints here.  You can get away with a 750w PSU but going 850w leaves room for upgrades later.
Hinjima approved 👍
https://linustechtips.com/topic/1609578-rate-my-first-build/#findComment-16710471
RX 7800 XT for $900+? Overpriced.
RX 9070 XT would be considerably faster - https://pcpartpicker.com/product/Bvjv6h/sapphire-pulse-radeon-rx-9070-xt-16-gb-video-card-11348-03-20g
Also - are you sure you want monitor with VA panel?
Pax vobiscum
https://linustechtips.com/topic/1609578-rate-my-first-build/#findComment-16710473
You can chop off about 210$ and have the same specs but more storage, like double the storage, a better PSU with more warranty and a somewhat better B850 mobo (completely optional but it has new bells and whistles + wifi)
https://pcpartpicker.com/list/wLLZHW
Or chop off about 140-150$ and also double the RAM capacity
https://pcpartpicker.com/list/bhNMDj
and with the extra money get extra storage or a more to your liking case with fans if need be etc etc
TL DR purely the choice of the compoenents was fine but how much you spend on some stuff like the 7800xt for nearly 1K was dumb
I'll have to say 6/10
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
https://linustechtips.com/topic/1609578-rate-my-first-build/#findComment-16710482
i should've added that im not from us and the gpu i picked is around 600$ here hahahha
https://linustechtips.com/topic/1609578-rate-my-first-build/#findComment-16710485
Mind sharing that country?
Cause if it is on PCPP it makes EVERYTHING a whole lot easier
But also if it is 600$ its also fine
https://linustechtips.com/topic/1609578-rate-my-first-build/#findComment-16710487
Not sure about the VA panel monitor and cheap case, but rest looks pretty good. Cheap cases aren't bad either.
current PC:
PC configs I used before:
https://linustechtips.com/topic/1609578-rate-my-first-build/#findComment-16710489
PCPartPicker Part List
CPU: AMD Ryzen 7 7700 3.6 GHz 8-Core Processor  ($275.00 @ Amazon)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  ($29.99 @ Amazon)
Motherboard: *Gigabyte B850 EAGLE WIFI6E ATX AM5 Motherboard  ($169.98 @ Amazon)
Memory: *Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($84.99 @ Newegg)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($97.97 @ B&H)
Video Card: *Sapphire PULSE Radeon RX 9070 XT 16 GB Video Card  ($892.98 @ Newegg)
Case: Deepcool CH560 DIGITAL ATX Mid Tower Case
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($119.99 @ Amazon)
Monitor: *MSI G272QPF E2 27.0" 2560 x 1440 180 Hz Monitor  ($215.99 @ Amazon)
Total: $1886.89
Generated by PCPartPicker 2025-04-21 09:40 EDT-0400
https://linustechtips.com/topic/1609578-rate-my-first-build/#findComment-16710492
1 hour ago, takehi said:
im from poland so the eu prices can be quite different
what other monitors can you find in your price range?
https://pcpartpicker.com/list/8ys2Yd
current PC:
https://linustechtips.com/topic/1609578-rate-my-first-build/#findComment-16710540
