I'm recording beats through a midi controller and I have a Focusrite Scarlett 2i4 and 1 Rokit 5 g3 speaker and I'm very new to this stuff and I don't want to spend another 150 and I don't have enough room for a second studio monitor but is the second one absolutely a NECESSITY? I've heard things about using a mono option but i'm really not sure so can you help me out here?
ASUS VG248QE 144hz | CM Storm Scout 2 Advanced | MSI Z77 GD65 | i7 3770k @ 4.2GHz | GTX 780 3GB FTW ACX |
Corsair RM750 | H100i | 8GB Corsair Vengeance | Corsair Neutron 64GB SSD | WD Black 500GB 7200RPM | ROCCAT Kone XTD | Microsoft Sidewinder
https://linustechtips.com/topic/160922-do-i-need-two-studio-monitors/
Without a second speaker you will not be able to get the channel balance or depth/spatial effects right.  You can do it on headphones but you will get better results using speakers.
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
Not if you are Van Gogh
depends , if you can tell the difference , you should or consider it as a later buy.
How would I set this up with one for now? I have the monitor plugged in to the interface and i tried to play some test sounds and it's not working
A lot of interfaces with stereo outputs will only work in mono if the output is plugged into a certain jack output, check your manual, failing that just plug it into your headphone output
CPU  Intel i7 5820k Motherboard Asus X99-S  RAM  32GB (8x4) Kingston Hyper X Fury GPU EVGA GTX 1080Ti SC2 iCX Case Fractal Design R4 Windowed Storage 500GB Samsung 850 Evo + 120GB Crucial M500 SSD + 2TB Seagate Barracuda + 1TB Western Digital Blue PSU Corsair RM1000 Display 2x Asus VS239HV Cooling  Noctua NH-D15 Keyboard  Corsair K70 RGB Mouse Logitech G502 Gaming Surface Razer Golitahus Extended Speed
I agree with this.
In Placebo We Trust - Resident Obnoxious Objective Fangirl (R.O.O.F) - Your Eyes Cannot Hear
Haswell Overclocking Guide | Skylake Overclocking GuideCan my amp power my headphones?
Yeah I should have known that. I've decided to buy a second even though I should have known to buy a pair in the first place lol. I'm going to build a shelf and set them up on the shelf.
If you're not recording in stereo technically a second one isn't necessary. though I've never heard of people having only one speaker. If you're recording in mono then it shouldn't make a huge difference, it'll just be a pain with the sound coming from on side of you the entire time.
Save up and get a second one, you won't regret it.
Edit. Just realised that audio interface has a switch to monitor in mono as well, so if you switch to that, you're getting the full sound through one speaker. Still, get another :)
i5 4670k @ 4.4 GHz | 16GB Corsair Vengeance | GTX 770 SLI | 256GB Evo Pro SSD | 2TB WD Blue | Corsair 350D | Windows 8.1 |
Asus VG248QE 144Hz Monitor | Roland Quad Capture Interface | Krk Rokit 6 Monitors |
Sometimes if you buy used, you get better deals if you buy each individually on Amazon. Sometimes.
