What does it say in the BIOS?
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
It's supposed to do that, assuming you have SpeedStep enabled. It slows down when idle.
it says min and max a 0.8GHz but dont see anywhere i can alter that ive set everything to auto to do with the CPU and still says 0.8GHz
it never goes over 0.8GHz though
Well, did it always feel that slow?
answer this question first if it tells you that it's at the proper speed there then it probably id but  try doing somthing that requires some CPU power to do you'll know pretty quickly if it's just displying the clock speed wrong. I've had problems similar to this with my cpu telling me it's getting way to hot at stock clocks with a liquid cooler it's pretty annoying to see it displayed wrong but it might just be somthing you'll have to live with I would worry about it aslong as everyinthing is working correctly.
and try downloading speccy to see if it shows the proper clock speed there  http://www.piriform.com/speccy
EDIT: oops just realized you answered what is says in the bios
Its bit weird since AI Suite shows that it should be running at 4.4GHz which is also propably incorrect if you haven't touched anything. It should be running at 3.9GHz under full load. Things you should try: Clear CMOS, update BIOS, Check that Turbo Boost is enabled.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
