Need Help with Airflow
As you can see, in the first picture, there is that wooden thing supporting the desk at the back, which will most likely block the rear exhaust. Also in the second picture you see that it is separated, you cannot remove the other half. Also I measured how deep the desk is, and it smaller than the case by atleast 5-10 cm if pushed back to the board if you catch my drift
Sorry I'm having trouble using the forums, I'm new
Ah I see. Welcome to the LinusTechTips forums! Don't worry, I'm happy to help. I think that piece of wood is providing some key structural support to your desk so no sawing that. If there is room in terms of the height to the underside of the desk and the height of the PC case. I'd build some kind of step that gets your PC case high enough for the rear exhaust vent to clear that wooden beam and the step could maybe come out a bit from the front of the desk to deal with the lack of space in terms of depth. You could pull your desk forward a bit so that the heat has room to dissipate. As long as the top exhaust won't be to close to the underside of the desk tho. Make sure your intake fans have filters that you clean regularly. Another option is something in this direction http://www.amazon.com/Syba-SY-ACC65010-Stand-Plastic-Adjustable/dp/B002LVUIS0/ref=sr_1_4?ie=UTF8&qid=1316492816&sr=8-4 that maybe your room does have space for. Any table or stand would only have to be large enough to accommodate the depth and width of your PC case if you eliminate the problem of having it under your desk. This will also give the top and rear exhaust fans all the room they need.
