Hello, recently i had dropped my cpu(ryzen 5 3400g) and bent 4 pins but i managed to straighten them all. When i put back the cpu in the motherboard and powered my pc on o saw that only one of the 2 ram slots worked.Today my new cpu came in(ryzen 5 5500) but the second slot still didnt work so i decided to clean the cpu socket as i spilled a little bit of thermal paste on it. i cleaned it with rubbing alcohol and a toothbrush just on the surface where the thermal paste was. Now, the cpu makes contact when i push it or something idk but right now my pc is on but i dont have any display signal and only the rgb from my mouse and headphones work. can yoi help me?
https://linustechtips.com/topic/1607363-help/
how long did you let it do memory training?
https://linustechtips.com/topic/1607363-help/#findComment-16695285
Let the socket air dry for like a day and see uf either of the cpu's still come on after a cmos reset.
https://linustechtips.com/topic/1607363-help/#findComment-16695317
22 hours ago, jaslion said:
Absolutly! But well patience and see if its still alive tomorrow
its still alive, i have changed my case and the fans are working but my keyboard and monitor still wont connect. Its better than before beacuse before i had to hold the cpu guard stick at its maximum and now i just leave it alone and its working. what do you think?
https://linustechtips.com/topic/1607363-help/#findComment-16696286
i think my motherboard is fried again beacuse i had the same problem in december and i connected the same mouse that i had back then and its not lighting up so i think im just gonna buy another motherboard or idk but thanks regardless
https://linustechtips.com/topic/1607363-help/#findComment-16696336
