here are some pics of my first build. Waiting for the AIO. not there yet with the cable management, will try to make it look a bit better. I also plan on getting a costume painted metal plate for the free space right from the motherboard.
Took me like 2h. Learned everything from LTT videos. (Thanks!)
Specs:
B850 Aorus Elite
Ryzen 9800 X3D
GeForce TUF 5070 TI OC
G.Skill RGB Trident Z5 Neo 2x16GB DDR5 6000mts
1000W ASUS TUF 80+ gold
Cooler Master MasterBox 600
https://linustechtips.com/topic/1607062-first-build/
Specs:
B850 Aorus Elite
Ryzen 9800 X3D
That is very clean for your first build.  Nice system, congratulations 🙂
There is nothing to really critique here.  1000w is a bit overkill, a solid 650w would be enough for this system 😄
But you have plenty of power if you want to get a faster GPU in the future.
https://linustechtips.com/topic/1607062-first-build/#findComment-16693706
Where's that CPU cooler? On the way?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1607062-first-build/#findComment-16693709
26 minutes ago, Hinjima said:
34 minutes ago, podkall said:
Where's that image.thumb.png.cf626f2450a5b18f76d10d0de9a4445e.pngCPU cooler? On the way?
current PC:
https://linustechtips.com/topic/1607062-first-build/#findComment-16693727
already looks better than 97.2% of other builds and their cable management
current PC:
https://linustechtips.com/topic/1607062-first-build/#findComment-16693729
