GPU upgrades *help*
Solved by SymphonyX7,
lol what about a silver stone strider essential 500 watt 80+ bronze? I'm on a seriously tight budget...and it seems to be the only one available locally..
That's good enough. But imo, it's only 34A on the 12V rails. That's relatively low. Other 500W PSUs supply up to 42A on the 12V rails. Also, isn't that Silverstone PSU expensive? I'd rather get a Seasonic S12II for the price, or an FSP Raider for that matter since the Raider actually reaches gold-level efficiency even at high loads.
If you are seriously on a tight budget, the FSP Hexa 500W or 550W and Corsair VS550 are your best choices. They're also noticeably cheaper than the Silverstone Essentials.
