Do you have 3 radiators? Or are you planning to do custom water cooling? Because otherwise you're never getting 3 radiators unless you're doing custom cooling,.
It looks like it might fit 3 360mm ratiators to answer your question.
I found this build: (I think the reservoir on the bottom is as big as a 360mm radiator)
current PC:
PC configs I used before:
https://linustechtips.com/topic/1606647-light-base-600-case/#findComment-16690907
Just for the first thing amazing workout on the PC it looks incredible , currently it is in the planning  and idea part , I have not even got the case yet but the reason I'm interested in three radiators is because I wanted to be ultra quiet borderline absurdly  but that is an incredible idea with the reservoir distribution plate I might have to steal that.
https://linustechtips.com/topic/1606647-light-base-600-case/#findComment-16691265
That's not my PC, but you can check it out here where I found it: https://pcpartpicker.com/b/bXj2FT
There are ways to be quiet without custom cooling
current PC:
https://linustechtips.com/topic/1606647-light-base-600-case/#findComment-16691348
6 intake ans 1 exhaust...rip
but it looks "cool"
Edited by thrasher_565
https://linustechtips.com/topic/1606647-light-base-600-case/#findComment-16691960
but it looks "cool"
I'm pretty sure they run it without glass, or have reverse blade
current PC:
https://linustechtips.com/topic/1606647-light-base-600-case/#findComment-16691973
i dont think thow corsair fans had revers blades that was before that time.
kinda dume to run no glass...
https://linustechtips.com/topic/1606647-light-base-600-case/#findComment-16691982
Still works I suppose, apparently the 14900K maxes out at 60C, and to top it off, they run older unstable BIOS.
6 intakes isn't the end of the world, despite the inefficiency of airflow, it's still drawing cold air rather than pushing hot air through the radiators, the pressure exhaust the air anyway regardless of the fan at the back too.
I'm more surprised it's quiet despite the possible turbulence the air will have as 3 and 3 fats push air against each other.
current PC:
https://linustechtips.com/topic/1606647-light-base-600-case/#findComment-16691986
ya some people dont care for cooling i guess. they may upgrade in a few years anyway.
but hey it was costly and looks cool all the matters.
runs hot check
loud fans check
costly check
re fill more often check
re past more often check
reduced speed do to heat check
uses more power check
https://linustechtips.com/topic/1606647-light-base-600-case/#findComment-16692019
runs hot check
loud fans check
costly check
I don't know where you're correlating 60C with hot temps, 60C is very cool for a 14900k
current PC:
https://linustechtips.com/topic/1606647-light-base-600-case/#findComment-16692436
