You mean to tell me that you have $40k worth of CPU system for a file server? Let me press X to doubt about this being real.
5 minutes ago, linustechtips fan said:
i got them for free so i dont care
ok do you care about noise or power consumption or maintenance because you're tasking this system with entry level tasks that basically an IOT device could do
40 minutes ago, linustechtips fan said:
running a file system than can handle 120gbs read and 60gbs write is not that easy
What nics are you using?
How many of those disks are you using?
Why 4 cpus? Your adding a lot of potiental for latency compared to a single CPU between all those CPUs and ram.
What OS? What protocol?
1 hour ago, linustechtips fan said:
and no os selected but raid 5 with 2 parody disks
Generally a raid5 means one parity disk, do you mean a raid50 or 6?
Generally raid5 or any parity raid doesn't have the best performance, look at a mirror solution for better performance.
and i can go down to 2 cpus minimum if that would be better
What server are you using? Some need the extra CPUs for running devices on. Look at the block diagram of how its wired internally
What protocol do you need? What are your clients?
