Budget (including currency): £1700
Country: Scotland
Games, programs or workloads that it will be used for: Mid to high end games like cyberpunk
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I have storage that i'm going to keep so i don't need more storage it's just basically the pc
https://linustechtips.com/topic/1605378-new-am5-build-help/
https://uk.pcpartpicker.com/list/gXzP9C
Got about 65 GBP left
You can use them to get case you like more and fans as well or a PSU with more warranty (the MSI one is still pretty solid tho and pretty good value)
I added a good 2tb m.2 for a bootdrive so you can save the storage you have purely for games and the such
I edit my posts for so if you saw a typo.... no you didn't, you are just crazy
https://linustechtips.com/topic/1605378-new-am5-build-help/#findComment-16682544
thanks for the list!
https://linustechtips.com/topic/1605378-new-am5-build-help/#findComment-16682547
This gives you both a board and gpu that support PCIe 5.0 along with a 2.5G LAN.
PCPartPicker Part List
CPU: *AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  (£407.29 @ Amazon UK)
CPU Cooler: *ID-COOLING FROZN A620 PRO SE 58 CFM CPU Cooler  (£29.99 @ Amazon UK)
Motherboard: *MSI B850 GAMING PLUS WIFI ATX AM5 Motherboard  (£177.77 @ Ebuyer)
Memory: *Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (£85.99 @ Amazon UK)
Video Card: *Asus PRIME OC Radeon RX 9070 XT 16 GB Video Card  (£774.95 @ Amazon UK)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  (£60.46 @ Scan.co.uk)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (£99.99 @ Amazon UK)
Total: £1636.44
Generated by PCPartPicker 2025-03-15 11:52 GMT+0000
https://www.tomshardware.com/software/windows/windows-11-free-or-cheap
A better look at those components.
https://www.msi.com/Motherboard/B850-GAMING-PLUS-WIFI
https://www.techpowerup.com/review/amd-ryzen-7-7800x3d/20.html
https://www.idcooling.com/product/detail?id=496&name=FROZN A620 PRO SE
https://www.techpowerup.com/review/id-cooling-frozn-a620-pro-se-cpu-air-cooler/
https://www.montechpc.com/air-903-base
https://www.techpowerup.com/review/montech-air-903-base/
https://www.msi.com/Power-Supply/MAG-A850GL-PCIE5
https://www.asus.com/us/motherboards-components/graphics-cards/prime/prime-rx9070xt-o16g/
https://linustechtips.com/topic/1605378-new-am5-build-help/#findComment-16682589
ARGB version of that build I posted up above.
CPU Cooler: *ID-COOLING FROZN A620 PRO SE ARGB 58 CFM CPU Cooler  (£31.99 @ Amazon UK)
Case: *Montech AIR 903 MAX ATX Mid Tower Case  (£65.00 @ Computer Orbit)
Total: £1642.98
Generated by PCPartPicker 2025-03-15 12:10 GMT+0000
https://www.montechpc.com/air-903-max
https://linustechtips.com/topic/1605378-new-am5-build-help/#findComment-16682602
Good builds, as far as mobo check features you may care for.
| CPU: Ryzen 7 7800X3D | MOBO: AM5 B650 Aorus Elite AX | RAM: G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | GPU: Sapphire PULSE Radeon RX 7900 XTX | SSD: Samsung 9100 PRO 1TB with heatsink | Cooler: Arctic Liquid Freezer II 360 | PSU: Seasonic Focus GX-850 | Case: Lian Li Lanccool III | Mousepad: Zowie GTF-X  / Vaxee PC / PA / Artisan Raiden Mid XXL| Mouse: Vaxee XE wired / Hitscan Hyperlight | Keyboard: Wooting 80HE zinc alloy raw - geon raw HE switches | Headset: Beyerdynamic MMX 300 (2nd Gen) | Monitor: LG 32GS95UV-B OLED 4K 240Hz / 1080p 480Hz dual-mode | OS: Windows 11 |
https://linustechtips.com/topic/1605378-new-am5-build-help/#findComment-16682607
