new First PC build
Solved by Kayul,
17 hours ago, Hinjima said:AMD has FSR that is similar to DLSS. DLSS is slightly better overall but FSR has caught up a lot in terms of visual quality.
The RTX 4060 is a decent GPU, the main reason people say its a bad card was the price to performance near release.
The RTX 4060 still performs great but I would recommend AMD at that price range.
Thank you. That really helps.
