Little Help if possible.
Solved by Tetras,
Can you please describe in more detail exactly what you mean, because it is really not clear what the problem is.
E.g. what is laggy/glitchy specifically? How does it manifest itself?
Based on your description so far, who knows, it could be anything really:
- Overheating leading to throttling 'cos the cooler isn't installed properly.
- Not enough RAM.
- Bugged driver installation.
- A conflict/clash between the previously installed monitoring software and the new card (can happen sometimes if it isn't uninstalled).
I'd look in the event viewer, if you can get that far.
Use a program like hwinfo to check temps and power draw.
Open up task manager to check nothing is taking all the CPU or memory.
