UPS Question
Go to solution Solved by MiszS,
Even at full power the system wont draw that much, I don't see a reason to upgrade
Hi, I recently bought a new PC, and I'm wondering if I need to upgrade my UPS (assuming I do but not 100% sure), if you guys could shed some light if the one I have is good enough and if not, what would you recommend?
Thanks!
PC Build:
CPU: AMD Ryzen 7 9800X3D AM5 Tray
Motherboard: Gigabyte X870 AORUS ELITE WIFI7
RAM: Corsair DDR5 64GB (2x32GB) 6000 CL30 Vengeance
CPU Cooling: be quiet! Water CPU Cooling Silent Loop 2 360mm
PSU: Corsair PSU 1200W RM1200x SHIFT 80+ Gold Fully Modular ATX 3.0
SSD: Samsung SSD 4.0TB 990 PRO NVMe M.2
Case: be quiet! SILENT BASE 802
GPU: Gigabyte GeForce RTX 5090 WINDFORCE OC 32G
Monitors: 2x Dell Alienware AW2723DF
Headphones: Beyerdynamic DT 1990 Pro
Microphone: Shure SM7B
Amp: Focusrite Scarlett 2i2 4th Gen
UPS I have:
Aviem Pro 2000VA (A system with a capacity of 2000VA/1200W).
Thanks!
https://linustechtips.com/topic/1603721-ups-question/
