Hi guys.
I have this weird issue with my Google Chromebook I purchased recently.
Whenever I move or touch the Chromebook, the green LED light near the charging port lights up.
The lid is closed.
I suppose it turns on,because battery discharges while it is off.
Does it have some kind of touch sensor.
It does auto turn on, when I open the lid, which I don't mind.
I do not want it to turn on each time I carry or move it.
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
https://linustechtips.com/topic/1603547-chromebook-weird-issue/
9 minutes ago, emosun said:
disable the auto turn on feature when the lid is opened to see if it still does it
Okay.How do I do that?
I did google research, no luck.
https://linustechtips.com/topic/1603547-chromebook-weird-issue/#findComment-16669575
i'm not sure really , i know it's possible with windows. it might need some sort of dev mode to be able to toggle that or any other setting that relates to different ways the thing can be woken up
https://linustechtips.com/topic/1603547-chromebook-weird-issue/#findComment-16669577
