RTX 5080 causing power problems?
I've recently went from a 3070 to a 5080, at first I was using the adapter and yesterday I got a 90° cable, the cable is H++ just like the adapter, the only difference is that it only uses 2 type4 connectors on my PSU (RM 1000x) instead of 3 like the adapter did, after the change my PSU now makes a clicking sound when the system turns on, like a few seconds after I press the power button on the case, and when it turns off it does the same sound plus some of my led fans blink really fast just once before the system shuts off. Also, the cable gets a little warm under load, around 370w, nothing concerning I guess, around I wanna say 40°c to 55°c range (I just touched it, I don't have a way to measure it).
This turning off video is in slow motion, it happens way faster in reality.
https://linustechtips.com/topic/1602261-rtx-5080-causing-power-problems/
First custom PC soon(-ish)!
Current part list:
Case: Corsair 4000D (✨WHITE✨)
GPU: Radeon RX 7900 XT
CPU: Ryzen 7 7700
CPU Cooler: Thermalright Peerless Assassin 120 (✨WHITE✨)
Mobo: ASRock B850 Pro RS
RAM: ADATA XPG Lancer Blade 2x16GB 6000MT/s CL30 (✨WHITE✨)
SSD: Lexar NM790 2TB
PSU: BQ Pure Power 12 M 850W
3 minutes ago, AlexithinkSR said:
Sorry, it's just two 3 second videos of the sound and blinking happening, the first one I press the power button, 2 seconds later (the GPU and mobo is already lit on at this point) then the click happens. the second one is turning off, right before the system shuts off for good (all led fans are already off at this point), they blink, the PSU clicks again and e shuts off.
some people might be able to play those videos, not me though,
not sure what the exact problem could be either, 1000W Corsair PSU shouldn't struggle with 5080
yeah, that's PSU's protections triggering,
I assume the PSU isn't really that old?
have you made sure the cables are nice and tightly inserted to avoid any cable related issues?
current PC:
PC configs I used before:
