Hi,
Going to get a new Deepcool AK620 to use in single fan mode, but throwing both fans out and get a good one, the best Corsair fans were ML120 Led Elite I believe, can it be used on the AK620 instead of inner fan? The fit and compatibility for cooler?
Thanks.
https://linustechtips.com/topic/1601659-ak620-fan/
Any 120mm fan that's 25mm thick will fit and work.
It's actually the Noctua NF-A12x25. That said, they're not that much better than the included fans, so I'd personally consider it a bit of a waste to buy new fans to replace these.
https://linustechtips.com/topic/1601659-ak620-fan/#findComment-16655592
