CPU and core temps VASTLY different: common?
Solved by Queek,
I checked the mount and it had very poor contact. It turns out that the sides of the pump contact the vram if it's oriented 90 degress off normal for this board, so the water block wasn't making contact with the CPU heat spreader.
I reoriented and remounted it and the super high temps are gone.
I'm running AIDA64 right now and the cores are averaging mid 60's and the cpu is sitting at 44. This is more what I'm used to for the difference between those two readings.
Thanks for the help troubleshooting... it turned out to be my own incompetence.
For those who follow in my footsteps:
If you have wildly different core and CPU temps (yes they are different numbers), check the mounting on your heatsink/water block.
