Need good power supply.
Go to solution Solved by HannahMusicEdits,
7 minutes ago, Hinjima said:
We get a lot of people from other countries so thats why I ask.
Have a look at the Thermaltake Toughpower GF1 750w.   10 Year warranty and its on the A:Tier on the PSU Tierlist.
Solid unit for 80 bucks.
I'll check the reviews, if this fits my needs, i'll consider this a solution
I want to upgrade from 450W Power Supply to atleast 600W, Because i'll be upgrading. Any good ones?
Current Specs:
MSI B450M VDH-PRO MAX
256GB NVMe
2x8GB 2666MHz
Ryzen 3 3200G
2x1TB 7200RPM Hard Drives
6 Molex PC Case Fans
1x 120mm CPU Fan
450W Power Supply
Upgrade Specs:
256GB NVMe
4x8GB 2666MHz
Ryzen 5 5600G
4x1TB 7200RPM Hard Drives
6 PWM non-RGB case fans (120mm)
2x CPU fan (120mm)
RX 580 8GB
Note: the 4x 1TB drives are just given to me, 100% health so i figured i can just use them to store my content creations, i don't mind how much it consumes or if "slow", i choose the 5600G because, why not i can use the intergrated graphics for my displays + diagnose if ever my GPU go bad.
https://linustechtips.com/topic/1600034-need-good-power-supply/
Current Specs:
256GB NVMe
2x8GB 2666MHz
Ryzen 3 3200G
1x 120mm CPU Fan
450W Power Supply
Upgrade Specs:
256GB NVMe
4x8GB 2666MHz
Ryzen 5 5600G
2x CPU fan (120mm)
RX 580 8GB
Plenty of good PSU's on the market.  What is your budget?
A decent budget PSU we usually recommend is the MSI A650BN.  Its well priced, safe and reliable 🙂
https://linustechtips.com/topic/1600034-need-good-power-supply/#findComment-16644330
I don't mind spending 80+ bucks if the power supply good, don't wanna cheap out on them tho
https://linustechtips.com/topic/1600034-need-good-power-supply/#findComment-16644333
Just now, HannahMusicEdits said:
Of course
https://linustechtips.com/topic/1600034-need-good-power-supply/#findComment-16644341
https://linustechtips.com/topic/1600034-need-good-power-supply/#findComment-16644350
29 minutes ago, HannahMusicEdits said:
450W Power Supply
What model do you have? The entire system should draw about 250W under load, so a decent 450W should be more than enough.
The 5600G also has less cache than the 5600, and performs worse. It's not just a 5600 with an iGPU. Whether or not that's worth it is up to you
https://linustechtips.com/topic/1600034-need-good-power-supply/#findComment-16644357
See if you can get the Mag A650GL
Also about 80 bucks.
Make sure to mark solutions, as it helps us find people who need help faster. Thanks!
I am human and am therefore prone to error, so I apologize if I make mistakes and I hope you understand.
Have a Nice Day!
https://linustechtips.com/topic/1600034-need-good-power-supply/#findComment-16644358
Just the DeepCool 600V2, a 450w with a "650w" boost for a short time, but i wanted to atleast be a future proof if ever i upgrade my pc, sure the 5600g has less cache but still would be better than using the 3200g, i don't mind at all though
https://linustechtips.com/topic/1600034-need-good-power-supply/#findComment-16644361
