How do you under volt fans?
I have 5 fans in my system, each undervolted to 7V with resistors. Those fans are connected to a digital rheobus that undervolt them another bit. With this setup I can control the fan speed as I want, and if I use the auto mode on the rheobus the PC is not too loud either.
  • MB MSI Z77A-GD65
CPU Intel Core i7-2600K + Corsair H60 + 2x Alpenfohn Wing Boost
RAM Corsair Dominator 16 GB
GPU MSI Radeon HD6950 Twin Frozr II / OC
SC Asus Xonar D2X
SSD Corsair Force GT 120 GB
HDD WD Black 1 TB + Blue 1 TB + Green 500 GB
PSU Corsair HX650
Case NZXT Phantom 820 Black
Rheobus NZXT Sentry LXE
Monitor: 3x LG IPS231P + Philips 298P4Q
Hi-Fi Onkyo HT-S3305
OS Windows 8.1 Pro
https://linustechtips.com/topic/160-how-do-you-under-volt-fans/#findComment-1407
Running a PWM controllable fan designed for 12v may run OK at a lower voltage as long as you do not go too low. PWM controlled fans have an IC chip inside and a rotation sensor. When the voltage to the fan gets too low the IC chip will fail to operate correctly. I have found that I was able to get the fans to operate OK at voltages down to about 6.2 volts. Below that the fans would not start reliably and the fan motor lacks torque.
Basically I never try to run fans below 7v. So PWM adjusts rotation, Voltage would adjust torque. so by bumping it down to say 7v you will probably get less noise.
▶ Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning. - Einstein◀
Please remember to mark a thread as solved if your issue has been fixed, it helps other who may stumble across the thread at a later point in time.
https://linustechtips.com/topic/160-how-do-you-under-volt-fans/#findComment-1577
connecting a low speed adapter to the fans is the best way to do it.
If you start pulsing the fans, it can cause them to make sounds that wouldn't be there if you had just undervolted them. This could be caused by the motor that is in the fans doing funny things when you do that to them.
https://linustechtips.com/topic/160-how-do-you-under-volt-fans/#findComment-1587
Or you could run the fan off the 12v and 5v rail for a delta of 7v.
See: http://www.overclockers.com/forums/s...d.php?t=372297
That way you dont need to buy anything.
https://linustechtips.com/topic/160-how-do-you-under-volt-fans/#findComment-1618
Resistors are far safer than the ghetto method.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
https://linustechtips.com/topic/160-how-do-you-under-volt-fans/#findComment-2217
i use the ghetto method for my fan on my H50 they run on 5v so its very quiet (= and the rest of my fans in my case Haf X is running of my motherboard in silent mode so everything is very quiet but yeah get some resistors far better for safety
https://linustechtips.com/topic/160-how-do-you-under-volt-fans/#findComment-2471
Just use resistors or change your settings in your motherboard drivers or BIOS is just easy if you do it that way. But when it comes to building your own are you asking to build your own PWM circut?
https://linustechtips.com/topic/160-how-do-you-under-volt-fans/#findComment-3055
  • 1 month later...
if you really are against using a resistor (they're really easy. If you can build a computer, you can do some simple wiring) then here.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&N=-1&isNodeId=1&Description=nzxt+sentry&x=0&y=0
NZXT makes some decent fan controllers. They're easy to use, you just plug in your fans to one of five connectors and away you go. A word of caution, the lowest they can output is 40% voltage so you can't go super low voltage. If you're not aiming for a voltage thats too low and you just want something thats horrifically simple, then this is probably what you should use.
Corsair Obsidian 800D | Msi GD-80 z68 | Intel Core i72600k (stock speeds at the moment) | Msi Gtx 570 twin frozr III | 8GB Corsair Dominator @1600mHz | Coolermaster evo 212 temporary) | Cooled by Gelid Wings | Intel SRT smart caching | Windows 7 ultimate x64
https://linustechtips.com/topic/160-how-do-you-under-volt-fans/#findComment-54825
