I have a Thermaltake Toughpower GF A3 750w power supply. I was wondering if there were any custom cables I could replace the included cables with. I am aware that they have to be a specific kind or else they could damage things. If anyone has any suggestions that would be sweet.
Here is my power supply: https://a.co/d/7ocWRA2
https://linustechtips.com/topic/1599932-power-supply-cables/
Are you looking for aesthetics boost?
If so, consider "cable extensions", cable extensions just extend the already plugged cables in PSU, so there's almost no risk of using those.
You hook up your PSU cables, that came with PSU, and then those cables plug into extensions which then come out of the back of the case and plug into the components.
current PC:
PC configs I used before:
https://linustechtips.com/topic/1599932-power-supply-cables/#findComment-16643876
I was looking for cables that would replace the PSU cables entirely. I don't really like the look of them so I was looking for a better looking option. I see that Thermaltake makes cables under the name TtMod Sleeve Cable but I was not sure if those would be able to be plugged straight into the PSU.
https://www.thermaltake.com/ttmod-sleeve-cable-cable-extension-white.html
https://linustechtips.com/topic/1599932-power-supply-cables/#findComment-16643966
these are cable extensions, you can see it in the name, and in the URL,
If you dislike the look of the cables, cable extensions is what you want, here is how they work:
  • At 7:42 you can see how these cables connect
current PC:
https://linustechtips.com/topic/1599932-power-supply-cables/#findComment-16644218
