Help
Go to solution Solved by Hinjima,
1 minute ago, Zumpy said:
You mean use 2 PCIe 8-pin (6+2) cables?
Thats the correct ones to use with AMD GPU's 馃檪
The 1x 12V-2x6 is only for RTX 4000 and 5000 from Nvidia.
You got all the cables needed to make your AMD GPU work.
2 minutes ago, Zumpy said:
So I bought the Corsair rm850x 2024 variant which doesnt have the 1x 12V-2x6 to Dual 8-pin (6+2) Cable. Ive got an AMD video card which utilises that cable so what should I do?
Use the normal 8pin cable ?
Refresh before you reply
https://linustechtips.com/topic/1597065-help/#findComment-16628313
Well, yea
https://linustechtips.com/topic/1597065-help/#findComment-16628315
Thanks I really panicked for a second, this is also my first time building a pc
https://linustechtips.com/topic/1597065-help/#findComment-16628320
No problem!聽 No panicking needed 馃槃
Fantastic to hear!聽 Congratulations on becoming a member of the PC building community 馃檪 Welcome.
You also picked a fantastic PSU for your build!聽 I got an RM1000x 2024 model myself.
I personally only use the RMx series from Corsair, probably used over 200 of them so far.
If you need any help with the build or get stuck, or you have any further questions or worries.
Please feel free to send me DM or tag me here, I will help you out and I dont mind it at all.
https://linustechtips.com/topic/1597065-help/#findComment-16628323
