It started with very bright purple and or white lights and then it went to the pictures below. I really hope it was just PUBG being old but I have a bad feeling about it. Also my drivers are all updated. Can someone please tell me if this looks like a game issue or if my graphics card is dying. It’s a 4070 super. IMG_6408.thumb.jpeg.a8a35cf8a50510dfcb0eae2a0e438f1a.jpegIMG_6405.thumb.jpeg.05728e0de2b029a03a71d0e8606c9d99.jpeg
https://linustechtips.com/topic/1597008-help-is-my-gpu-dying/
Nothing here indicates a dying gpu.
CPU : Ryzen 7 7800X3D @ -30mv All core
CPU Cooler : Thermalright Frozen Prism 240mm AIO
Mobo : Asrock B650m Pro RS Wifi
Ram : 32GB (2X16GB) Lexar Ares 6000MHZ CL 28-36-36-68
GPU : MSI Gaming X Slim 4070Ti Super 16GB ( 308W PL +140 Core +1000 Memory )
Storage : 2TB Verbatim Vi5000 Gen 4 NVME
PSU : Thermalright TG-750w 80+ Gold ATX 3.0 PCIE 5.0
Case : Fractal Design Pop Mini MATX
Case Fans : 3 X Thermalright TL-C12C-S RGB
Monitor :27" Samsung Odyssey G5 2560 x 1440 180 HZ IPS
Keyboard : HyperX Alloy Core RGB
Mouse : Corsair M65 Elite RGB
Headset : Corsair HS35 Gaming Headset
https://linustechtips.com/topic/1597008-help-is-my-gpu-dying/#findComment-16628263
you're killing ur gpu, ur making it artifact.
UserBenchmarks: Game 417%, Desk 121%, Work 464%
CPU: Intel Core i5-13600K - 123.4%
GPU: Nvidia RTX 5080 - 354.6%
SSD: WD Blue SN570 NVMe PCIe M.2 1TB - 298.3%
RAM: Corsair Vengeance LPX DDR4 3200 C16 2x16GB - 109.7%
MBD: MSI PRO Z690-A DDR4
Monitor: X32 4k 480hz OLED
https://linustechtips.com/topic/1597008-help-is-my-gpu-dying/#findComment-16628338
On 1/23/2025 at 5:54 PM, Salted Spinach said:
You can start by installing MSI Afterburner and checking YouTube videos about the application's settings
I already have that downloaded. I havent touched in settings or options in it tho. I was thinking about running a GPU Stress test to see if there is really something wrong with it. Would yall recommend Furrmark 2 (the ASUS ROG version)? or something else? I can only do the free versions tho.
https://linustechtips.com/topic/1597008-help-is-my-gpu-dying/#findComment-16640815
8 hours ago, AlecM said:
Also, It recently did this (see picture). Is this a problem with the game or GPU?
Try multiple games. If things look strange in more than one game, you have a GPU problem.
Also, the potential solution I suggested earlier just applies a temporary downclock on the core. It can't cause any damage
https://linustechtips.com/topic/1597008-help-is-my-gpu-dying/#findComment-16641168
