Budget: $3000 aud
Country: Australia
Haven't ever made a pc or anythingh even similar to it before, so before i finalize and start buying the parts i was just wondering what much smarter people then me thought and if i made and bad choices or mistakes anywhere, p.s also wondering if i should also buy some fans seperately.
Games, programs or workloads that it will be used for: i want to be able to play games like silent hil 2 remake, helldivers 2, and total war warhammer 3, along with using the computer sound and music design for uni. with being able to run games in genral at a stable 1440p
Other details: after going over parts and many other things and talking to people who are much better informed with pcs then i. This is the list of parts i have chosen
Component   Selection Price
CPU   AMD Ryzen 7 8700G 4.2 GHz 8-Core Processor AMD Ryzen 7 8700G 4.2 GHz 8-Core Processor $423.00 Buy
CPU Cooler   ARCTIC Liquid Freezer III 240 56.3 CFM Liquid CPU Cooler ARCTIC Liquid Freezer III 240 56.3 CFM Liquid CPU Cooler $149.00 Buy
Motherboard   Gigabyte B650 EAGLE AX ATX AM5 Motherboard Gigabyte B650 EAGLE AX ATX AM5 Motherboard $267.00 Buy
Memory   Corsair Vengeance RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory Corsair Vengeance RGB 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory $157.00 Buy
Storage   Kingston KC3000 2.048 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive Kingston KC3000 2.048 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive $203.95 Buy
Video Card   Gigabyte GAMING OC GeForce RTX 4070 Ti SUPER 16 GB Video Card Gigabyte GAMING OC GeForce RTX 4070 Ti SUPER 16 GB Video Card $1399.00 Buy
Case   Montech XR ATX Mid Tower Case Montech XR ATX Mid Tower Case $78.00 Buy
Power Supply   Gigabyte UD750GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply Gigabyte UD750GM 750 W 80+ Gold Certified Fully Modular ATX Power Supply $129.00 Buy
Monitor   Asus TUF Gaming VG27AQ1A 27.0" 2560 x 1440 170 Hz Monitor Asus TUF Gaming VG27AQ1A 27.0" 2560 x 1440 170 Hz Monitor $239.00 Buy
if anyone has any recomendations that I add anything or make some changes to the list that would be a great help.
thank you for taking the time to read this 🙂
https://linustechtips.com/topic/1595154-first-ever-pc/
2 minutes ago, idklikebruh said:
1399 dollars seems alot for 4070 ti super. idk tho i can be pretty dumb sometimes
yeah it is a bit but it's actually on the cheaper side of ones i could find, i was thinking a cheaper one but there wasn't a whole lot about it so i changed
https://linustechtips.com/topic/1595154-first-ever-pc/#findComment-16614981
Just now, idklikebruh said:
i live in britain so idk what prices are like in australia but on pc part picker i can find 4070 ti super for like 800 pounds
yeah aud is worth alot less so things over here are just really expensive when it comes to this type of stuff, one of our dollars is only 50 cents in pounds
https://linustechtips.com/topic/1595154-first-ever-pc/#findComment-16614989
Ok so theres some stuff
PCPartPicker Part List: https://au.pcpartpicker.com/list/Gp2npK
CPU: AMD Ryzen 7 7700 3.6 GHz 8-Core Processor  ($439.00 @ Centre Com)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($65.00 @ Centre Com)
Motherboard: MSI B650M GAMING WIFI Micro ATX AM5 Motherboard  ($169.00 @ PCCaseGear)
Memory: Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($142.00 @ MSY Technology)
Storage: Western Digital Blue SN580 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($165.00 @ JW Computers)
Video Card: PowerColor Hellhound Radeon RX 7900 XTX 24 GB Video Card  ($1549.00 @ PCCaseGear)
Case: Silverstone FARA 515XR ATX Mid Tower Case  ($59.00 @ PLE Computers)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($149.00 @ Centre Com)
Total: $2737.00
Generated by PCPartPicker 2025-01-05 10:58 AEDT+1100
basically saved on wasted money and now you have a MUCH faster pc even budget left meaning you can get a faster cpu, more storage,...
https://linustechtips.com/topic/1595154-first-ever-pc/#findComment-16614999
DDR5-6000 CL30 > DDR5-6000 CL36. You want a ATX 3.0 psu for these RTX 40XX cards due to the adapter.
CPU: *AMD Ryzen 7 7700 3.6 GHz 8-Core Processor  ($439.00 @ Centre Com)
CPU Cooler: *Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  ($65.00 @ PCCaseGear)
Motherboard: *MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  ($279.00 @ Computer Alliance)
Memory: *Patriot Viper Venom 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($142.00 @ MSY Technology)
Storage: *Patriot P400 Lite 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($157.00 @ MSY Technology)
Video Card: *Gigabyte EAGLE OC GeForce RTX 4070 Ti SUPER 16 GB Video Card  ($1349.00 @ MSY Technology)
Case: *Montech AIR 903 MAX ATX Mid Tower Case  ($89.00 @ PCCaseGear)
Power Supply: *MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  ($149.00 @ Centre Com)
Monitor: *Asus TUF Gaming VG27AQ1A 27.0" 2560 x 1440 170 Hz Monitor  ($239.00 @ Centre Com)
Total: $2908.00
Generated by PCPartPicker 2025-01-05 11:05 AEDT+1100
https://linustechtips.com/topic/1595154-first-ever-pc/#findComment-16615013
11 minutes ago, At0mhandl3r said:
but i've heard that liquid cooling is better then normal air fan cooling? is that true or is it not much of a difference?
It depends. For the cpu's here doesn't matter as they are VERY efficient. The thermalright also goes up against most 240/280mm aio's.
https://linustechtips.com/topic/1595154-first-ever-pc/#findComment-16615038
