Depends on how the fan software is setup. Mine defaults them to temperature curve that really doesn't seem to work....
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/159510-pwm-fan-headers/#findComment-2124921
if you plug it to psu molex it will run at max speed, if you plug it into mobo it will control it.
https://linustechtips.com/topic/159510-pwm-fan-headers/#findComment-2124935
Depends what the stock parameters are in the BIOS.
https://linustechtips.com/topic/159510-pwm-fan-headers/#findComment-2125040
If you have set it to run at full speed, it will do so. Now if you have it set to run according to ie cpu temp, it'll will lower speed when cpu is already running cool. Difference between 3pin and PWM is that PWM doesn't adjust with voltage jumps as do 3pins. Like 3pins have mainly 3 settings, 12V, 7V and 5V. PWM will adjust speed freely between 12V and 5V, maybe even have it to 0rpm if fan allows that.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/159510-pwm-fan-headers/#findComment-2129386
