hi all,
my pc keeps randomly crashing with black screen and the fans go crazy.
I have just tried a fresh windows install, and updated all the drivers for the gpu, bios update, windows update,
when I look at event viewer the last error appears to be this:
I am running windows 10 with the below specs
i7-6700k
hyper x 16gb ddr4 2400mhz
1080ti
z-170e MOBO
any help would be greatly appreciated
https://linustechtips.com/topic/1594943-pc-keeps-crashing-help/
37 minutes ago, Gaffers91 said:
hi all,
i7-6700k
1080ti
z-170e MOBO
I'm not sure the error you've posted is responsible for your PC crashing. Try this instead and choose critical error:
Event Viewer -> windows logs -> System. Right click and choose filter current log. Under event level, toggle critical.  And choose logged: 24h for example if it happened within the last 24h. Press OK. then if you have had critical logs it'll show up. If nothing is shown, choose another event level or more, error for example. Post your findings here.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1594943-pc-keeps-crashing-help/#findComment-16613554
