I just started a new build for my gaming pc my specs are a
asus prime b550m-a WiFi ii
Ryzen 5 3500
2x8gb of delta T-force ram
crucial p3 plus 2tb m.2 ssd
xfx Rx 580 8gb
evga 500w psu
And I’ve got every thing plugged in but I have no display on my monitor everything turns on tho I’ve tried to reseat the ram and try with one stick but still nothing and tried to reset cmos no display still I’ve tried all display ports on my gpu dvi, hdmi and display but no dice please help me
https://linustechtips.com/topic/1592916-i-need-some-help/
2 hours ago, Sawa Takahashi said:
Did you try to clear the CMOS memory ? It couldn't hurt.
Another suspect is the Crucial P3 SSD. Amazon had a bad batch or counterfeits and they got plenty of issues.
Good luck !
Yeah I have tried that but still no dice but I did figure it out that my cpu was the wrong chipset so ima change my cpu out with a Ryzen 5 5600g
https://linustechtips.com/topic/1592916-i-need-some-help/#findComment-16601032
The 5600g is certainly an upgrade and it will allow for integrated graphics too. But according to Asus, you board should support the 3000 series ryzen processors.
Good luck !
https://linustechtips.com/topic/1592916-i-need-some-help/#findComment-16601302
