Budget (including currency):
Country:
Games, programs or workloads that it will be used for:
hey,
I was wondering if this power supply would be safe to use for my build with a 3060.
thanks
https://linustechtips.com/topic/1592183-good-power-supply/
I would not trust that. It's only rated 80 plus. I would not even dare build a system with anything less than 80+ bronze. That thing is... let's just say what you find in the cheapest of prebuilts at best.
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
https://linustechtips.com/topic/1592183-good-power-supply/#findComment-16595730
P.S.
Although efficiency rating is not directly correlated to PSU built quality, 80 plus rating is an obvious red flag since for modern PSU to reach 80+ Gold is relatively easy and the price difference between the gold, bronze or even lower on the same PSU capacity is probably not significant like a decade ago, going step way lower (even lower than bronzer rating) is something that shouldn't be done
My System: Ryzen 7800X3D // Gigabyte B650 AORUS ELITE AX // 32GB 6000MHz DDR5 Silicon Power Zenith CL30 // Sapphire Pulse AMD Radeon RX 7900 XT OC with mod heatsink on the metal plate  // Phanteks P300A  // Gigabyte Aorus GEN4 7300 PCIE 4.0 NVME // Kingston NV2 Gen4 PCIE 4.0 NVME //
Seasonic Focus GX-850 Fully Modular // Thermalright Frost Spirit 140 Black V3 // Phanteks M25 140mm // Display: Bezel 32MD845 V2 QHD // Keychron K8 Pro (Mod: Gateron black box ink; Tape mode on PCB and Keycaps) // Razer Cobra Wired Mouse // Audio Technica M50X Headphone // Sennheiser HD 650 // Genius SP-HF180 USB Speaker //
And Laptop Acer Nitro 5 AN515-45 for mobility
Phone:
iPhone 11 (with battery replaced instead of buying new phone for long term and not submitting (fully) to Apple Lord
https://linustechtips.com/topic/1592183-good-power-supply/#findComment-16595734
9 minutes ago, C2fashy said:
How about this one?
That is something that I would be more likely to trust as a unit with an 80+ Bronze PSU rating is more likely to include decent quality components and the necessary safety measures to keep your system safe.
https://linustechtips.com/topic/1592183-good-power-supply/#findComment-16595748
What is your budget, country and CPU?
current PC:
PC configs I used before:
https://linustechtips.com/topic/1592183-good-power-supply/#findComment-16595810
