Hey,
I build my first PC a few days ago and can atleast vouch for the 5600x. It's been awesome, I do use it in combination with the 6700xt (second hand) tho, which performs really well on games like Warzone!
My cpu did not reach more than 90% yet. (I'm a person that uses Chrome with having a LOT of tabs open, while gaming and using Discord.)
Also I have been using 16gb's of ram instead of your 32. For me it's more than enough. I do have a 750watt psu, your psu probably wont be enough if you're planning to buy the same gpu as I have or better.
4 hours ago, GreenLeaf said:
oh and don't get this PSU under any circumstances
I second this, a cheap EVGA unit is a much better choice, I’ve run them in computers for years including a 24/7 work server with zero failures.
AMD Ryzen 5900X
T-Force Vulcan Z 3200mhz 2x32GB
EVGA RTX 3060 Ti XC
MSI B450 Gaming Plus
Cooler Master Hyper 212 Evo
Samsung 970 EVO Plus 2TB
WD 5400RPM 2TB
EVGA G3 750W
Corsair Carbide 300R
Arctic Fans 140mm x4 120mm x 1
I realise this is is $140 extra, but I just wanted to put it forward for consideration:
$100 gets you onto the AM5 platform with a solid motherboard and 32Gb of the fastest RAM, so it will be faster now and far better for future CPU upgrades (you'd be starting at roughly the same as a 5800X3D for gaming performance and even faster for productivity!).
$40 extra on a PSU that is more reliable and will have a little more headroom for a future GPU upgrade. Personally I would recommend going for an 850W, but that is ANOTHER $60 and not really required if you're aiming for RTX3070 / RX6700XT levels of GPU performance.
PCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($178.99 @ Newegg)
Motherboard: ASRock B650M-H/M.2+ Micro ATX AM5 Motherboard  ($99.99 @ Amazon)
Memory: TEAMGROUP T-Create Expert 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($84.99 @ Amazon)
Storage: Crucial P3 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($118.00 @ iBUYPOWER)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200 RPM Internal Hard Drive  ($64.98 @ Amazon)
Case: Montech AIR 903 MAX ATX Mid Tower Case  ($79.98 @ Amazon)
Power Supply: Corsair RM650 (2023) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.99 @ Corsair)
Total: $716.92
Generated by PCPartPicker 2024-12-06 06:35 EST-0500
Main rig: Ryzen 7 7800X3D, RTX3080Ti FE, 32Gb Teamgroup Create-T DDR5-6000C30, AC Freezer3 280mm AIO, Asrock Steel Legend X670E, M.2 2Tb Samsung 990 Pro, M.2 1Tb WDSN550, SATA 8Tb WD80EFAX, Corsair HX850, LianLi O11 Air Mini + 3x NF-A14's, MSI MPG 271QRX (27"/1440P/360Hz), Gigabyte M27Q (27"/1440P/170Hz), Asus PA248 (24"/1200P/60Hz), G815 kbd, G Pro X Superlight 2, Audezee Maxwell.
Games room "TV rig": 5800X3D, AC Freezer2 280mm AIO, ASUS Prime B450M, RTX4080S w/iChill AIO, 32Gb TridentZ DDR4-3600C14, M.2 500Gb & 1Tb WDSN550, 8Tb WD80EFAX, BeQuiet Straight 1000W,  LianLi O11 Air Mini, LG G4 (55"/4K/120Hz), G815 kbd, G502 mouse, LG G1 Soundbar / Audezee Maxwell.
Lounge HTPC: Minisforum UM760 Slim, Ryzen 5 7640HS, 16Gb DDR5, 1Tb M.2, LG C2 (42"/4K/120Hz), Logitech Touch K400.
Laptop: LOQ16, RTX4060, 16Gb DDR5, 2x 2Tb SN990 M.2.
NAS: Synology 1812+, 3Gb RAM, 3x16Tb Seagate EXOS RAID5, 1Tb MX500 cache, 3x3Tb WDRED RAID6, 120Gb SSD cache.
  • 2 months later...
Total: $716.92
This is a really interesting build, I'll probably stick with this, but get a 1TB SSD and another 1TB HDD, instead 2TB on both. I already have.a 256GB SSD that I can use as a boot drive.
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor  ($119.89 @ Amazon)
Motherboard: MSI PRO B550M-VC WIFI Micro ATX AM4 Motherboard  ($99.99 @ Amazon)
Memory: Corsair Vengeance LPX 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($64.98 @ Amazon)
Storage: *Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($89.97 @ B&H)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200 RPM Internal Hard Drive  ($59.99 @ Best Buy)
Case: *Montech AIR 903 BASE ATX Mid Tower Case  ($65.00 @ Newegg)
Power Supply: *MSI MAG A650BE 650 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($59.99 @ Amazon)
Total: $559.81
Generated by PCPartPicker 2025-02-13 19:34 EST-0500
Whats the budget anyways? 600$ you can get a competent am4 build with a 5600(x) + 6700xt/6800 with a mix of used and new, 700$ up that to a 6950xt or am5 with the 6800
You can save $60 or more with a 1Tb WD Blue drive... use that for boot and put games on the SSD as it will be much faster than any SATA-based drive.
Split your game library between that an an old SATA "spindle" hard drive.... I would default games onto the older drive and then move them over to the SSD/boot drive if you find they're especially slow... that way you don't clog up your faster drives with games you only play occasionally.
