Hey guys,
I built my rig about November last year, and up until yesterday there have been no issues. I'm fairly computer literate so I've spent a few hours troubleshooting the issue myself, and even gone as far as to reinstall my OS (tried all other possible software fixes and it was time for a refresh anyway) so now I'm convinced this may be a hardware issue which is worrying. Whether it's just web browsing or playing a game, my cursor freezes. Only for a split second. I also noticed when Skyping with my friend some of the time when this happened it also disconnected my headset for a moment and I had to go and reselect it in Skype (it's a USB headset), so I'm unsure if it's an issue with the USB ports on my motherboard or what the issue is (I have suspicions it may be the motherboard as whilst I've been having this issue the computer doesn't seem capable of restarting, and I have to manually restart by switching the PC off and back on again at the power supply.
My specs are as follows:
Core i5 4670K overclocked to 4.2GHz (very stable, has been fine for months)
8GB Corsair Vengeance 1600MHz
2TB Seagate Barracuda 7200RPM hard drive for storage
120GB Intel SSD
Galaxy GeForce GTX 770 2GB
Gigabyte Z87-HD3
I'm getting fairly concerned especially since I am going to a LAN party tomorrow so this would be majorly inconvenient if I can't get this sorted (though to be honest I don't expect to as I believe it may be a faulty component)
Thanks in advance to anyone who is able to help
Case: NZXT H440 Black & Red | CPU: Intel Core i5 4670K OC'd 4.2GHz | Mobo: Asus Maximus VII Ranger Z97 | RAM: 8GB Corsair Vengeance DDR3 1600MHz (was a 16GB kit :c) | Storage: 1x 240GB Samsung 850 Evo, 1x 240GB Samsung 840 Evo, 1x 2TB 7200RPM drive | GPU: Asus GeForce GTX 970 Strix | PSU: Corsair AX860 | Cooler: Corsair H100i | OS: Windows 8.1 Pro/Windows 10 Preview
Primaries: HTC One M8 16GB Gunmetal Grey, iPhone 6 64GB Space Grey| Secondaries: iPhone 5 16GB white, Samsung Galaxy S3 Blue 16GB
Primary laptop: MacBook Air mid 2013 base model | Other devices: iPad mini 32GB wifi Space Grey
https://linustechtips.com/topic/159044-intermittent-freezing/
I wouldnt have reinstalled os. that would be a last ditch effort. I cant remember the name of the program but it is built into windows and show you when an error occured and what you probably did that day. typically if its suddenly begins freezing you probabbly installed a program that is bugged or broken. what does your task manager say under performance when the freezing occurs?
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
https://linustechtips.com/topic/159044-intermittent-freezing/#findComment-2119122
I'm on my secondary PC at the moment, shortly after I posted this my PC got a BSOD and now refuses to boot (does not display and mouse and keyboard keep turning on and off)
I'm leaning towards the motherboard or possibly the graphics card, but it seems like it's the mobo
EDIT: I've managed to get the PC to boot, so there's that, I'll look into it
https://linustechtips.com/topic/159044-intermittent-freezing/#findComment-2119146
Interestingly when the freezing occurs (which is completely random, no pattern in frequency) nothing drastically changes in Task Manager under Performance
I'll take another look at this tomorrow, but it's 2AM at the moment and I am over this so I'll leave it for now, cheers for your help and I'll see what I can do tomorrow
I'm pretty convinced it's the motherboard to be honest
Another thing to note is the simple act of running Minecraft and playing a YouTube video at 720p at the same time seemed to accelerate the frequency of the freezing quite drastically, so I'm also thinking it could be the graphics card though I don't see why that would interfere with my USB ports
https://linustechtips.com/topic/159044-intermittent-freezing/#findComment-2119239
could be bad memory. if you have onboard graphics, take your gpu out and see if that fixes it. check the memory, powering up with only 1 stick in and see if its stable like that; then check the other stick. check to see if there is a crash report. that will tell us if its a software issue or hardware issue.
https://linustechtips.com/topic/159044-intermittent-freezing/#findComment-2119268
I've taken my GPU out and booted with on board graphics and the issue seems to have disappeared, which is a shame because the only other GPU I can use for tonight is a GTX 570, which should be fine for the games we intend to play (Counter Strike Source/GO, Dawn of War etc) all old games that really don't need that much horsepower, though that GPU is in another machine a friend was going to borrow, so I guess my laptop is going to have to step in
Thanks for your help, I'm going to keep testing and trying to recreate the issue before I install the 570 just to be sure, and if I can't then I'll have to get on to my retailer and claim warranty for my 770
Cheers
https://linustechtips.com/topic/159044-intermittent-freezing/#findComment-2121780
