What CPU?
English is not my first language, so please excuse any confusion or misunderstandings on my end, also I like to edit my posts a lot.
F@H-Stats
The Rigs:
Xenon:
CPU: 2x Xeon E5 2690 V3
RAM: 64GB DDR4 2133 RDIMM
MoBo: Supermicro X10DRi-T4+
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
RAM: 48GB DDR4 3200 UDIMM
MoBo: ASRock B550M Pro4
The Laptop (Lenovo Legion 5 15IAH7):
CPU: Core i5 12500H
RAM: 16GB (2x8GB) DDR5-4800
GPU: RTX 3050 Ti mobile
OS: Windows 11 Home
The Tablet:
Dell Latitude 7212 Rugged Extreme Tablet (Core i5 8350U/8GB RAM)
OS: Windows 11 Pro
https://linustechtips.com/topic/1590321-help-me-choose-one/#findComment-16582469
3 minutes ago, Xentrix said:
7700x
You could easily get away with an air cooler with that chip, for example a Peerless Assassin 120 SE would do fine.
If you really want to use an AIO, both will be perfectly sufficient, so I'd choose the cheaper option.
F@H-Stats
The Rigs:
Xenon:
Hydroxide:
CPU: Ryzen 5 5600
GPU: RTX 3080 12GB
CPU: Core i5 12500H
OS: Windows 11 Home
The Tablet:
OS: Windows 11 Pro
https://linustechtips.com/topic/1590321-help-me-choose-one/#findComment-16582473
i already know which air cooler i want if i ended up choosing air cooler so i'm asking about AIO. Whats the different between magnetic bearing in Corsair and Fluid Dynamic in Arctic?
https://linustechtips.com/topic/1590321-help-me-choose-one/#findComment-16582476
The mag levs should be longer lasting and quieter running, but with fans now the bearing noise is so minimal it doesnt really matter for the noise aspect as the movement of the air itself will most likely be louder anyway. Though i would also recommend an air cooler, they have a much longer lifespan and are cheaper. What air cooler were you thinking?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1590321-help-me-choose-one/#findComment-16582483
peerless assassin or  noctua NH-D15
https://linustechtips.com/topic/1590321-help-me-choose-one/#findComment-16582487
phantom spirit is better than both and is similarly priced to the peerless assassin
aio wise id look at the thermalright aios as they seem to be competing with the liquid freezer iii performance wise
https://linustechtips.com/topic/1590321-help-me-choose-one/#findComment-16582502
Oh and for AIOs for AMD, i would say, between those 2, the AF3 hands down, best in class cooling for AMD, includes an offset bracket, VRM cooler to boot is just pretty nifty and is more likely cheaper than the corsair
EDIT: Also definitely check out @Somerandomtechyboi's suggestions above, thermalrights AIOs are hidden gems just like their air coolers (less so hidden as time goes on tbf), and they have coolers that beat the NH-D15 more recently released than the PA for the same price
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1590321-help-me-choose-one/#findComment-16582503
okay thanks!
https://linustechtips.com/topic/1590321-help-me-choose-one/#findComment-16582507
2 hours ago, TatamiMatt said:
AF3
I think you meant LF3, right?
2 hours ago, Xentrix said:
okay thanks!
I definitely agree that the LF3 is a better choice on AMD.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1590321-help-me-choose-one/#findComment-16582650
