Memory made for 3rd generation intel processor will work w/ 4th intel processor
Go to solution Solved by Osmium,
Yes it will. They all are made to run on DDR3. However once a DDR4 memory controller is used on the motherboard that is when the older RAM will no longer be compatible.
Hi everyone,
If I buy a motherboard with intel core i7 4770k, is the memory, which is made to work with intel generation 1, 2 and 3 processors, will work with the processor I want to take? Thank you!
Motherboard: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131980
CPU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16819116901
RAM: http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231314
Thank you. If you have any suggestions for these 3 components let me know. I can't raise prices too much and if it's possible give me links from this site: newegg.ca
"If you do not take your failures seriously you will continue to fail"
not sure what you are specifically asking but all that stuff works.
CM Storm Switch Tester MOD (In-Progress) - http://linustechtips.com/main/topic/409147-cm-storm-switch-tester-macro-mod/
       Ammo Can Speaker 02 (Completed) - http://linustechtips.com/main/topic/283826-ammo-can-speakers-02/       A/B Switch V 0.5 (Completed) - http://linustechtips.com/main/topic/362417-ab-switch-v0
     Build 01 - The Life of a Prodigy -  http://linustechtips.com/main/topic/13103-build-01-the-life-of-a-prodigy/             Build 02 - Silent Server 3000 - http://linustechtips.com/main/topic/116670-build-02-silent-server-3000/
