So I’ve been looking at these 3 monitors and I can not figure out what to chose they all fit in my budget, any help would be really appreciated
1. Samsung Viewfinity S5 LS34C500
2. AOC CU34G2XP
3. Samsung G5 Odyssey C34G55
they’re all 3 pretty close to each other as far as I could read except for the lower refresh rate of the viewfinity.
The most important part for me is honestly just an upgrade from my current 60hz monitor since I’ll be gaming a bunch of different games mainly on it but I can’t figure out the pros and cons of the monitors myself.
https://linustechtips.com/topic/1589877-widescreen-recommendation-for-3080/
Can you explain to us why you've narrowed down your search to these 3 monitors out of the vast ocean of monitors on the market?
What is your criteria? Your budget? Your country? Your available retailers? Your desk size restrictions?
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
Yes of course. Mainly it was price and that I can get them in a store close to me
my main criteria is just 1440p preferably widescreen, a higher refresh rate than my current 60hz 1440p monitor, budget is no more than 335 usd, I live in Denmark and those 3 monitors are the only widescreen 1440p monitors I could get in stores that fit my budget, available retailers would be danish stores so I don’t think that would help to know and I have about 3 meters of desk length but I’m gonna use 2 monitors since I want my current 27” monitor to be my second monitor
i digest a lot of f1 data and stuff when they’re driving so for that more monitor=more better but I’ll be using it mainly for gaming
Out of these 3 specific models, I'd recommend the AOC.
The fist Samsung is just much worse than the other two.
The second Samsung is comparable to the AOC, but has a pretty extreme curve which isn't for everyone. And Samsung is notorious for bad quality control and firmware bugs. So if the price is similar, go with the AOC.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
