So one of the front led's is broken post-52184-0-09654200-1401350234.jpg have i not plugged something in or is it broken
|| MAELSTROM ||
|| i5 3570K W/ CM 212x @ 4GHz || r9 290 Windforce || Corsair Obsidian 450D || 2tb HDD + 120gb 840 evo SSD || 2x4gb Hyperx Fury Blue
https://linustechtips.com/topic/158864-450d-led-broken/
Check if it is plugged in in the correct spot.
It should have small print on the wire internally telling you what it is. Use this as a reference;
I really wish that we'd just make organic hardware already, that grows and adapts to the demands it needs to meet. That way, grannies' computers can be floppy sacks of organicness and the 12 year old Minecrafters will look like the guys that only do bicep curls, and the nerdy programmers will finally have justice, with their body-builder rigs that skipped leg day.
CPU: i7-4770k 4.8GHz | Motherboard: Asus Maximus Hero | RAM: 16gigs 2133MHz | GPU: SLI Gigabyte OC 2gb 770's | Case: INWIN GRone | Storage: 1tb Blue, 60gb SSD | PSU: Silencer MK II 950w | Cooling: Modded H100i
https://linustechtips.com/topic/158864-450d-led-broken/#findComment-2116793
Is the connector connected to the power LED header on the motherboard?
Im not sure but one of them works so i thought they would be on the same plug
|| MAELSTROM ||
https://linustechtips.com/topic/158864-450d-led-broken/#findComment-2116794
no, one of them is a hdd activity LED and the other is a power LED
Oh ok when i put my new r9 290 in ill re arrange them, i was tired and the mobo doesnt clearly explain where to put which one so i just put them in were ever  :P
|| MAELSTROM ||
https://linustechtips.com/topic/158864-450d-led-broken/#findComment-2116802
what motherboard do you have? also this is one of the reasons they include this little thing:
makes it really easy to connect those fiddly little cables
https://linustechtips.com/topic/158864-450d-led-broken/#findComment-2116878
The dreaded extreme 4 :P ill figure it out with trial and error
|| MAELSTROM ||
https://linustechtips.com/topic/158864-450d-led-broken/#findComment-2117035
  • 7 months later...
hi !
i've bought this case and an msi motherboard(z97  gaming 3) since 3 month and during 2 months the two activity led were brighting but since one week none led works.
i've checked the connection to the motherboard and there are corrects.
What can i do please ?
(sorry for my bad english i'm french) ^^
https://linustechtips.com/topic/158864-450d-led-broken/#findComment-3800092
ok but now none leds bright but when i try to connect hdd led like the picture below it works but power led no,thank you.
you should have the HDD light horizontal below the power LED? i don't know what gave you the idea to put it on the JFP2 header? the cables are labeled, so try and connect everything the way the picture says (+ and- in the right spot aswell) then power on the pc, check if the power led is on and copy a large file from your primary drive to a secondary or external device and check if the HDD led pduces any light (note: it wont be as bright as the power led...)
hi !
if you are 100% sure you haven't changed anything, and everything else still works then its most likely that the case LED's actually died... this is very rare though and extremely unlikely... another (even more unlikely) cause could be that just the front panel header on your motherboard broke... but its very unlikely only this part broke... the only other causes that i can think of would result in a lot more than just the led's breaking so i don't think thats the case...
https://linustechtips.com/topic/158864-450d-led-broken/#findComment-3801275
i've tried to copy a large file between 2 hhd but nothing :/ , i don't know if the power led is dead but the hdd led works on the jfp2 ( yes it's strange)
Thank you
 the power and hdd led are basically the same however and dont have any electronics other than an led.. so if they light up/work in any sort of confguration its safe to say your motherboard header somehow broke....
its still very strange that your jfp1 header doesn't seem to function correctly (or at all) and everything does... if connecting it as described in your maual on jfp1 really doesn't work and the lack of power / HDD led really bothers you you can consider sending it back, as the board is most likely somehow damaged....
https://linustechtips.com/topic/158864-450d-led-broken/#findComment-3802434
when all the cables are on the jfp1 just the power button and reset button woks none leds , so the problem is maybe the motherboard but it's strange because she's perfectly intact
yeah.. but i can't think of anything else because if the leds are dead then they wouldn't work on the jfp2 either
https://linustechtips.com/topic/158864-450d-led-broken/#findComment-3802762
