Budget (including currency): 2100 - 2300 AUD
Country: Australia
Games, programs or workloads that it will be used for: Games at 1440p especially new ones
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):  https://au.pcpartpicker.com/user/Mosha/saved/gQzmxr this is what i was thinking for the build but i have questions about the graphics card, i know powercolour is a reputable brand for radeon gpu oems but when comparing https://au.pcpartpicker.com/product/QgcgXL/powercolor-fighter-oc-radeon-rx-7900-gre-16-gb-video-card-rx-7900-gre-16g-foc
 to https://au.pcpartpicker.com/product/3v7scf/asus-dual-oc-radeon-rx-7900-gre-16-gb-video-card-dual-rx7900gre-o16g its seems like the asus version is cheaper by $50 while also having better performance so should i just go for the asus version. Another question is if building the setup in a smaller case such as the Asus Prime AP201 or Lian Li A3 would cause issues such as thermal throttling or any other performance issues, there is also the fact that i never owned a gaming rig nor made one if that would be a factor with me opting for a bigger case for better cable management.
https://linustechtips.com/topic/1588502-gpu-and-case-help/
Country: Australia
7900GRE have stout cooling, and the AP201 is mesh.  Air won't be an issue.
I'd probably pop for the 9600x since you can afford it.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1588502-gpu-and-case-help/#findComment-16569518
12 minutes ago, Lightneng said:
How about the Lian Li A3 cooling capabilities, also do you have any answer about my question for the 2 gpus
I don't know the Lian Li at all, I had one of their cases and won't again probably.
I'd go with the ASUS.  The 7900GRE is a great card and it shows that 2 fans can cool it just fine.  I usually recommend 3 fan cards only, but the 7900GRE is an exception.  Either brand is really good though, so can't go wrong.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1588502-gpu-and-case-help/#findComment-16569528
I would go with the Asus Dual card as the cooler and fans is very good. Also it's small and lightweight which is a plus compared to many other brands that uses giant coolers, which makes the card very heavy. Also Powercolor really saved on quality this time. I have a Red Devil RX 7900 XT and the build quality of the cooler is horrific.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1588502-gpu-and-case-help/#findComment-16569540
Firstly, never pay for the X when there's a non-X version, that's AMD CPU rule 101. So 7600.
GRE turns out to be ok, but you can get a 7900XT in budget so I would.
PCPartPicker Part List: https://au.pcpartpicker.com/list/f6cqsp
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  ($285.77 @ JW Computers)
CPU Cooler: Thermalright Peerless Assassin 120 SE 66.17 CFM CPU Cooler  ($55.00 @ Scorptec)
Motherboard: Gigabyte B650M GAMING WIFI Micro ATX AM5 Motherboard  ($155.00 @ MSY Technology)
Memory: Silicon Power XPOWER Zenith RGB Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($159.00 @ Mwave Australia)
Storage: Samsung 980 Pro w/Heatsink 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($237.09 @ Amazon Australia)
Video Card: Sapphire PULSE Radeon RX 7900 XT 20 GB Video Card  ($1098.00 @ Scorptec)
Case: Corsair 4000D Airflow ATX Mid Tower Case  ($135.00 @ Centre Com)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($145.00 @ Centre Com)
Operating System: Microsoft Windows 11 Home OEM - DVD 64-bit  ($40.00)
Total: $2309.86
Generated by PCPartPicker 2024-11-11 20:53 AEDT+1100
https://linustechtips.com/topic/1588502-gpu-and-case-help/#findComment-16569591
