1 minute ago, Bareon9 said:
Actually today i went their shop and they have 7900xtx in their stock but they told me this case doesnt fit at all and pearless assasin cant cool the cpu and i cant use this motherboard with this cpu are they correct?
They are wrong on the cpu cooler as well as motherboard working with CPU.   Needs a bios update is all at worst.
Not sure on fitment though.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
Almost 70mm of clearance with this combo
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
Oh then screw that shop.
Get the parts, build it, enjoy it.
OnePlus Ecosystem:
3D Printing:
12 minutes ago, TatamiMatt said:
1st of all, peerless assassin can definitely cool the cpu
2. You can use the motherboard with that cpu however you may require a BIOS update.
3. and in what way does the case not fit? GPU length? Is the 7900xtx available and what you asked for? Because if so, it absolutely does fit
GPU length
Available space in case for GPU
He told me i need to pick 360mm liquid cooler at least he reccomend me corsair.So i can use that motherboard at all and probably i will upgrade it in 1-2 months but rightnow my budget cause a problem for me when i go there yes its avaible and with same price when i go there he want to build my pc with in my budget when i told im i pick that case he told me its doesnt fit at all and then i say can 7900xtx fit in  400d and he told me i can pick coolermaster master box td500 and its way expensive then both cases
Stop listening to him.
You don't need a 360 aio to cool a 9700x.  Watch a few videos as proof.
Don't upgrade that board soon, it's more than fine for the life of that CPU.
As to the case, if the stated measurements work, then it fits.  Math is math.
I know it's hard to compare two chaps on the Internet vs one supposed expert in person.... But take time, do research and be confident in what you want.
OnePlus Ecosystem:
3D Printing:
Yes probably when he pick himself the part he goes for all the expensive yes i am not a pc builder expert so i wonder for cooler and motherboard because i went cheap and when i uptade bios my system works fine right and probably im going to upgrade my motherboard but rightnow my budget doesnt let me
Yes u are right and i dont think he is kinda expert just a worker wants the sell but thanks for the all the replys and help probably i pick this buildScreenshot_2024-11-07-14-46-15-045_com.android.chrome-edit.thumb.jpg.98d59f65519c60dbfe12580f0ef10095.jpg
Just need a PSU and you're set .
OnePlus Ecosystem:
3D Printing:
Normally case have a psu do i need to buy a new good one?
Ahh, I see that now.  I personally use an 850w for my 7900XTX but they can be run on a 750.  I just don't know how good that one is.
OnePlus Ecosystem:
3D Printing:
This psu should be fine or do u have any rec?
That PSU is Tier F on this, meaning you can use it if you have it but don't buy it....
https://cultists.network/140/psu-tier-list/
Look for any Tier A or B PSU.  I prefer Super Flower, but Corsair's RMx line is solid.
OnePlus Ecosystem:
3D Printing:
Okay i will looking a new psu within my budget probably go for corsair rmx line but again thanks for all the help.
Glad to help.  It's a process, as you can see.  Sorry for the issues with the shop you're buying from.
OnePlus Ecosystem:
3D Printing:
