Budget (including currency):80000TL like 2200usd
Country: Turkey
Games, programs or workloads that it will be used for:
Other details  first of all hello i hope everyone doing fine i want to build a system for gaming and for work normally i build this example build some parts doesnt exist here but normally i live in usa but im going to stay here little bit so i can purchase that parts later
Screenshot_2024-11-04-11-09-26-948_com.android.chrome-edit.thumb.jpg.a9bb2aefb5356b7f46454b859425f7fe.jpgScreenshot_2024-11-05-10-03-03-974_com.android.chrome-edit.thumb.jpg.80a86b823ca9c4d72f808730bbc2b829.jpg
I am suspicious because the parts in the 4080 system below seem to be knockoff
but normally i think i can change the parts later below system i can put 4070ti super and improve somethingScreenshot_2024-11-06-08-35-52-846_com.android.chrome-edit.thumb.jpg.5d40df13b31083e62ab1e2bbc87bf891.jpg
https://linustechtips.com/topic/1587971-system-build-advice/
if you are going AM5 unless you need a micro atx motherboard the asrock taichi boards are the way to go overkill vrm great bios and good cpu support i have a 7800X3D a 6700XT and an asrock B650E taichi lite alongside 32 gigs 6000 mhz ddr5 ram and at 1080p all my games are maxed out
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565027
If i get that motherboard i think i need to downgrade my gpu is it worth it ?
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565034
Taichi is pretty overkill, you can easily go lower spec, asrocks pg lightning (atx version), HDV/M.2 (atx version) or taichi lite are all good choices if you like asrock, especially with a 4000D, can easily fit an ATX. There are also many other choices that are perfectly fine, most higher end, and even mid tier AM5 boards have crazy overkill VRMs for the cpus so most choices so long as their higher tier than the bottom are perfectly fine
Also id get the non icue version of the 4000D if you can, it should be quite a bit cheaper.
Also for RAM, get 6000CL30 (like the last builds RAM choice), higher than 6000 starts to get a bit unstable on AM5
The Palit 4080S is a good version of that GPU, though im not sure how kosher it is as im not familiar with the site, the main thing is that it seems a little cheap, all else look fine
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565050
in my opinion the B650E taichi light is deff worth it outs of all the reviews i have read the taichi B650E baords are the best you can always upgrade your gpu later i never cheap out on a mobo this B650E taichi lite can handle any cpu amd tosses at it
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565051
What do you think about b650 tomahawk or b650 steel legend?
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565060
I found 400d airflow with psu should upgrade for that case? I found msi b650 tomahawk or ASRock X670E Pro do u think they are worth it? And what build should i get if i get rtx 4080 super build i cant do much upgrade but if i went for sapphire pulse rx7900xtx or palit 4070ti super gamerock black what do u think it will be best i can get rtx 4080 build and i think i can change part time being
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565067
And everyone says u need to cool that cpu u need 360mm liquid cooling is that true?
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565069
Oh not at all, im running a 7800X3D with an air cooler. Doesnt get above 60/65 while gaming and 75 while stress testing
Im not sure if you have the option but thermalright have some great air and liquid cooling options for super cheap
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565071
Actually i have this option i can change to pearless assasin is it good ? And what do you think above question and  i can change 400d for h6 flow with psu and is ASRock B650M PG Lightning matx good?
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565073
i run a 6700XT 7800X3d and a B650E taichi lite and im beyond happy
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565076
Peerless assassin is perfect, there is a phantom spirit if that option exists, it should be about the same price but just a little better in every way.
Im running a B650 tomahawk, but i will admit even that is a little overkill. X670 boards are even moreso as theyre the next tier up of motherboard, it mainly depends on the price of them. the cheaper the better until a certain point (not better quality but still good quality but money saving).
The main thing to get in a motherboard is to get one that does what you need it to do, paying for a higher quality motherboard than you need may just net you features youre not going to use and so are paying additional money for nothing. For example E boards (B650E or X670E) have PCIe5, thats their whole thing, but PCIe5 will only really become useful by the next socket of boards (maybe) so will be relatively useless for now. It isnt a hindrance but theres just no need to pay extra for something that isnt going to be taken advantage of.
Im running a 7900xtx myself, in straight power its on par with the 4080S, though you dont get DLSS (which is the nicer upscaler) and it wont be nearly as good for ray tracing, but if you dont mind FSR (amd upscaler) and want a cheaper GPU that will perform as well as the 4080S, the 7900xtx is that GPU. The 4070TiS is about on par with a 7900xt.
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565077
Yes its same price but i dont know why bjt motherboard options are low i can get ASRock B650M PG Lightning matx or i can pay extra 20 and get MSI MPG B650 Gaming Plus WiFi which one is good sorry for asking so much question but i dont know much about pc building and i dont think i use raytracing much and high tier gpu like 7900xtx and rtx 4070ti super it wont be issue but which card should i think in 7900xtx only have sapphire pulse and i read its like kinda base model or i can get 4070ti super models and its cheaper?
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565079
Sapphire pulse is kinda base model but with a much better cooler than AMDs own card, that or the 4070TiS, mainly depends on price, how much are the cheapest versions of each card?
The Asrock motherboard, i cant find a lot online about the matx PG lightning but from what i can see, it has slightly worse thermals and VRMs than some other boards, what website are you using so i can see the full offering list? Or send it over yourself, price included and ill give my thoughts on the best value boards imo.
If there are very minimal options other than those 2 id say the gaming plus wifi as it has better VRMS and is ATX so youll get slightly more features and will also come with built in wifi
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565099
Cheapest rx 7900xtx in here pulse and i think its equals to 1060$ that palit version isa 1022$ and its like cheapest one and in site its all tl but i think you got the idea normally i dont want to build here i bring my laptop but i dont want to use daily basis all motherboard options are here and i think i have the max budget for motherboard 8900 but if u say pay extra and get this i will try
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565113
From what i can see, its a weird mix of very budget boards, and mid tier and up, no middle ground budget boards, the gaming plus wifi, either the B650 or B650M are the best choices imo, with the B650 being both slightly better but also slightly more expensive (about 300 Lira)
For GPUs if the 7900xtx is $1060 and 4070TiS is $1022, id get the 7900xtx, youll be a tier up in performance for a small increase in price. Which verison of GPU you get doesnt really matter so long as it has a minimum of a decent cooler that can support the heat output of the card, and the only real difficult to cool card is the AMD base coolers as the had issues with cooling, but all partner boards have that issue fixed
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565122
Great boards too.
A motherboard is the foundation of a build, but only si much as it provides the slots and power you need
Almost any b650 does that just fine.
I would never downgrade a GPU to get a better motherboard over what I need.
Get a solid board and go from there.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565183
2 hours ago, Dedayog said:
Great boards too.
 I go for the msi b650 gaming plus but for gpu there is no stock for rx 7900xtx if i go for rtx 4080 i need to downgrade some pieces do u think its worth it?
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565364
Depends what you would downgrade.
2200 USD is enough for a 4080super build with a nice CPU and RAM and storage.
What is your build looking like?
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16565378
Right now like this i think its equal to 2270 USD if i pick rtx 4080 cheapest version 2400 usd what do u think about this system ? And i have a questions do u think gpu will fit case ( im going to change cooler to pearless assasin) and is motherboard cpu combo will work fine?
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16566170
That's a really strong build.  Good pairing with 9700x and 7900xtx.
Will definitely push that monitor well.
Can you get 2tb of Gen 4 SSD for that price?  You don't need cutting edge 7000mb/sec for gaming at all.  Hello use 2000/sec as well as SATA still.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16566250
I believe the 7900xtx has been sold out sadly, the equivalent 4080 puts him above budget, @Bareon9, the 4700TiS is also an option, its quite close in performance and price to the 7900xtx, it is slightly worse value for money, but thats Nvidia, you could also try putting the thermalright cooler in and removing the deepcool and getting a slightly cheaper SSD and you might be able to fit the 4080 in closer to your budget
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16566264
When i go their shop they told me this case doesnt fit at all and pearless assasin cant cool the cpu and i cant use this motherboard with this cpu are they correct? Or they just want to sell me some stuff? And probably i would pick some 2tb gen 4 ssd
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16566265
Actually today i went their shop and they have 7900xtx in their stock but they told me rtx 7900xtx and  this case doesnt fit at all and pearless assasin cant cool the cpu and i cant use this motherboard with this cpu are they correct? Or they just want to sold me some stuff?
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16566267
6 minutes ago, Bareon9 said:
When i go their shop they told me this case doesnt fit at all and pearless assasin cant cool the cpu and i cant use this motherboard with this cpu are they correct? And probably i would pick some 2tb gen 4 ssd
1st of all, peerless assassin can definitely cool the cpu
2. You can use the motherboard with that cpu however you may require a BIOS update.
3. and in what way does the case not fit? GPU length? Is the 7900xtx available and what you asked for? Because if so, it absolutely does fit
GPU length
Available space in case for GPU
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1587971-system-build-advice/#findComment-16566270
