23 minutes ago, Bareon9 said:
I want to buy 2000$ pc with monitor Mostly i am going to do render but i will play games as well what can i build with my budget
What country are you in? What specific programs will you be using,? What kind of monitor are you looking for.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1587803-2000-build-advice/#findComment-16563678
I will buy it in usa and mostly 3d programs and u5. I think 2k 1ms ips monitor sounds good because im going to play games too
https://linustechtips.com/topic/1587803-2000-build-advice/#findComment-16563697
For the 3d rendering and UE5 stuff are you wanting to do Ray Tracing? Again, specific programs would be a big help. Depending on the programs and what you're trying to do some hardware is better than others. Just a generic answer such as this doesn't help as much as you're thinking it does.
https://linustechtips.com/topic/1587803-2000-build-advice/#findComment-16563776
Yes u are right and Honestly i will use blender,maya houidini and u5 but i think i dont do the ray tracing stuff
https://linustechtips.com/topic/1587803-2000-build-advice/#findComment-16563787
9900x is a great multithread CPU, Peerless Assassin should be enough to cool it and then some. 4070 super is faster than a 7900 XT in rendering, so that's why I chose that. Case and PSU are both good. Chose 64gb ram for the better high end rendering in Blender, and that monitor is good for gaming and should be a solid all around for you.
https://pcpartpicker.com/list/mNm2FZ
https://linustechtips.com/topic/1587803-2000-build-advice/#findComment-16563833
https://www.newegg.com/p/2AM-00CN-00057
Montech AIR 903 BASE, ATX Mid Tower Case $59.90 ETA Date: 11/8/2024
PCPartPicker Part List
CPU: *Intel Core Ultra 7 265K 3.9 GHz 20-Core Processor  ($399.98 @ B&H)
CPU Cooler: *ID-COOLING FX360 PRO 82.5 CFM Liquid CPU Cooler  ($59.99 @ Amazon)
Motherboard: *Gigabyte Z890 EAGLE WIFI7 ATX LGA1851 Motherboard  ($229.99 @ B&H)
Memory: *Patriot Viper Venom 64 GB (2 x 32 GB) DDR5-6400 CL32 Memory  ($169.99 @ Amazon)
Storage: *HP FX900 Pro 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($129.99 @ Amazon)
Video Card: *Gigabyte WINDFORCE OC GeForce RTX 4070 SUPER 12 GB Video Card  ($599.97 @ Amazon)
Power Supply: *MSI MAG A750GL PCIE5 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.00 @ Amazon)
Total: $1678.91
Generated by PCPartPicker 2024-11-04 22:10 EST-0500
https://linustechtips.com/topic/1587803-2000-build-advice/#findComment-16563997
