If you're getting that in the capture but not the original then the two things that spring to mind are either compression artefacts or there is some colour/level shift or conversion going on. Given the capture bitrate seems to be set to 100Mbps that shouldn't be a problem. I'm using half that for 4k60.
Dunno if something needs tinkering with in colour format/colour space. I'm not on a PC with OBS installed so can't see what other options there are.
it is in the recorded file itself even before editing, i have recorded in the av1 codec,is it because of that ? or the color formar and color space ?
You could try using a 4:4:4 color format, that might solve the problem. My assumption is that the chroma subsampling of 4:2:0 eliminates many of the color shades in that gradient.
And now a word from our sponsor: 💩
ℑ𝔣 𝔶𝔬𝔲 𝔬𝔫𝔩𝔶 𝔫𝔬𝔱𝔦𝔠𝔢 𝔭𝔢𝔯𝔣𝔬𝔯𝔪𝔞𝔫𝔠𝔢 𝔭𝔯𝔬𝔟𝔩𝔢𝔪𝔰 𝔴𝔥𝔢𝔫 𝔶𝔬𝔲 𝔥𝔞𝔳𝔢 𝔞 𝔰𝔱𝔞𝔱 𝔠𝔬𝔲𝔫𝔱𝔢𝔯 𝔬𝔳𝔢𝔯𝔩𝔞𝔶 𝔞𝔠𝔱𝔦𝔳𝔢, 𝔶𝔬𝔲 𝔞𝔯𝔢 𝔪𝔢𝔯𝔢𝔩𝔶 𝔩𝔬𝔬𝔨𝔦𝔫𝔤 𝔣𝔬𝔯 𝔭𝔯𝔬𝔟𝔩𝔢𝔪𝔰 𝔱𝔬 𝔟𝔢 𝔲𝔭𝔰𝔢𝔱 𝔬𝔳𝔢𝔯. 𝔗𝔲𝔯𝔫 𝔬𝔣𝔣 𝔱𝔥𝔢 𝔠𝔬𝔲𝔫𝔱𝔢𝔯 𝔟𝔢𝔣𝔬𝔯𝔢 𝔞𝔰𝔨𝔦𝔫𝔤 𝔣𝔬𝔯 𝔥𝔢𝔩𝔭 𝔞𝔫𝔡 𝔰𝔢𝔢 𝔦𝔣 𝔶𝔬𝔲 𝔰𝔱𝔦𝔩𝔩 𝔫𝔬𝔱𝔦𝔠𝔢.
ᑐᑌᑐᑢ
