Hello all,
I am in the process of making an MC Server. Ive been told that the hardware required isnt steep so I made a server with spare parts I had kicking around.
Server Specs:
-i5 6600k
-16gb DDR4
-AsRock Motherboard
-WD 770 1tb NVMe SSD
-Windows 10
The problem now is, no matter what I do or try my Server will always lag behind. 'server thread/warn can't keep up is the server overloaded' It will be bad like 2k+ ms behind. I invited friends over to see if it would make a difference. Unanimous decision that it was lagging and stuttering. It was originally on an HDD and then I upgraded to an NVMe. Still the same issue. I've seen people say to use Java 8 I am using Java 13. I tried a few things but Idk anything about this so any and all solutions are welcome. If you have any questions Id be happy to answer them!
Marline
Top Loop:
Thermaltake Pacific PR2U Dual 5.25" Bay D5 Pump/Resorvior Combo / EK ZMT Tubing / A mixture of Chrome Plated Brass Rotary Fittings Bit Fenix and Alpha Cool / Alphacool NexXxos 280mm 45mm Thick Copper Pass-through Radiator / Alphacool NexXxos 140mm 45mm Thick Copper Radiator / XSPC G1/4 1/2ID Chrome Compression Fittings / Freeze Mod AM4 CPU Waterblock / 3x Noctua Redux 140mm fans
The Bottom:
Custom Made 2mm Thick Steel PSU Shroud / Aqua Computer Aqua Tube POM Reservoir / Alphacool Eisdeck 5 w/D5 655 Pump / EK ZMT Tubing / Alphacool 45° Chrome Plated Brass Rotary Fittings / Bitfenix 90° Chrome Plated Brass Rotary Fittings / Alphacool Chrome Plates Brass Pass Through Fittings / Koolance QD3 Quick Disconnects / Bitfenix Full Cover Water Block 2080ti / Alphacool NexXxos 200mm 45mm Thick Copper Radiator / Noctua Chromax 200mm Fan / The fluid I used for both was EK Cryofuel Acid Green
Computer Specs:
Thermaltake F31 Suppressor / Ryzen 9 3950X / 32gb G. Skill 3200mhz RAM / Asus B550-E motherboard / Zotac RTX 2080 ti 11gb / EVGA 1000 GS PSU / Samsung 970 Evo Gen3 NVMe SSD / Western Digital SN850X Gen 4 NVMe SSD / 4x PNY 120 gb SSDs in RAID 0 / 1x Spectre 512gb SSD / 1x Patriot 240gb SSD / 1x 1Tb Western Digital Black 7200RPM HDD / 1x 2Tb Seagate 5400RPM HDD / Windows 10
https://linustechtips.com/topic/1587219-help-with-minecraft-server/
1 minute ago, tkitch said:
is it modded or running vanilla?
It is all 100% Vanilla
Marline
Top Loop:
The Bottom:
Computer Specs:
How much memory have you allocated (you can see the memory statistics in the GUI)?
Which Java version have you installed? Don't you need like the latest JRE or JDK (JDK 23) to run the latest version of the server?
PLEASE MARK COMMENTS AS SOLUTION IF SATISFIED!!
bigger number better, makes me look cooler.
10 minutes ago, Skipple said:
What's the system monitor looking like? What's pegging?
I haven't Checked. Ill have to run that when I get a moment to see.
Marline
Top Loop:
The Bottom:
Computer Specs:
Im not sure. Ive ran Java 8 and 13. I havent run 23 yet. My server Version is 1.20.2 I have tried both 2gb and 4gb of allocated space. On start up it doesnt lag at all. Then after like 5 seconds the lag starts.
Marline
Top Loop:
The Bottom:
Computer Specs:
Uninstall all Java versions (easy to do from control panel), and install JDK 23 (don't install any JRE).
1.21 is out. Why not upgrade?
4 GB should do fine. I mean you have 16 gigs, so why not allocate 6 or even 8? But yeah, 4 should be enough, but more doesn't hurt.
That sounds weird. If it were a Java version issue, then this probably shouldn't be a symptom. Inspect task manager and see for weird activity. Monitor CPU clock speeds and temperature. Restart Windows if haven't already.
Or even better, why not run the server on Linux instead of Windows?
Haswell has, well, a point
How many people are using the server? If you've got a ton, it may be overloading.
Definitely crank the allocated memory up, that will help.
Also, check your temps. If it's old hardware, it's possible the paste job is dried out.
Any Errors being thrown in Event Viewer? Or in the MC logs?
I will have around 15 people on the server at the maximum. Im gonna try to run Java 23 and see if that does what we need it to do. I will have some updates here soon!
Marline
Top Loop:
The Bottom:
Computer Specs:
But how many are on when the warning is thrown?
1. Myself. Sometimes even before when its loading.
Marline
Top Loop:
The Bottom:
Computer Specs:
I'm also seeing some reports that it could be bad networking. Can you speed test from the server?
Also, check task manager > (more details)> performance > cpu > right click graph > change graph to > logical processors
Maybe there is a heavily loaded core
Good to know, and I assume that if you sit there for a while it doesn't just go away?
Yes it doesnt stop or go away when I am just standing there. I also Speed Tested on Ookla on the server Im getting 550+ Mb/s Down and like 22Mb/s Up. That should be plenty I would presume.
Marline
Top Loop:
The Bottom:
Computer Specs:
What if your client PC is directly connected to the server over ethernet? Then try if the problem occurs again, but first, try all the stuff that I mentioned earlier.
Just so its noted. My set up goes from Coax -> to Modem -> to Router -> to 48 Port Switch -> to Server, Client PCs, and Wifi. The main machine is over the wire. While all the other machines are over the Wifi. Also I am using Radmin VPN to allow connections.
Marline
Top Loop:
The Bottom:
Computer Specs:
VPN for LAN? What?
I just said out of curiosity to directly connect the client PC to the server over ethernet. Nothing in between. If that is even possible of course.
1 hour ago, Haswellx86 said:
VPN for LAN? What?
Local direct Connection is not possible. The VPN is for LAN and for WAN Players to join.
Marline
Top Loop:
The Bottom:
Computer Specs:
This could absolutely be causing your issues, but also fairly easy to isolate. Requiring all traffic is required to flow through a third party is going to cause added latency, it's just a matter of how much and how well that traffic is prioritized.
Why not? You can certainly test this for yourself by typing the local IP/Port of the server on your client.
ask me about my homelab
This is getting complex.. I was hoping to just use a VPN so I can invite peeps through it. Goodness.. What should I do instead? Would I have to use the IP of the Server along with the port instead of the VPN? I've never been successful in making that happen. Call me what you will but I don't know how to most of this. Hence why Im here lol.
Marline
Top Loop:
The Bottom:
Computer Specs:
Before you start taking action, I would isolate the issue. Connect locally to the server using its local IP and see if that eliminates the issue. If it does, then you know it's more than likely the VPN.
No, just disable the VPN.
Then where will I find the IP address to use for the Server? Is it under the Server Settings?
Marline
Top Loop:
The Bottom:
Computer Specs:
Okay so I disabled the VPN and setup the server with the IP. I am able to connect to it no problems. But the Lag and stuttering are still happening. I tried updating Windows and Rebooting. I also reinstalled the LAN Drivers for my motherboard, along with changing the speed to 1G Full Duplex on the Network Port. The Task Manager says that I am well within spec for CPU Usage it doesnt go about 12%. The Network seems to be good too. I dont see any hiccups or spikes that are out of the ordinary. I am able to connect to the server but the Lag is still present. Any other Ideas that I can potentially try? Or data that you request?
Marline
Top Loop:
The Bottom:
Computer Specs:
