please help
Solved by GuiltySpark_,
24 minutes ago, AlwaysWright said:i have a light for cpu and ram on the motherboard after following these steps, im guessing i just wait?
Generally these lights together indicate a serious issue communicating with the CPU, RAM or both. Do the basics like reseating the RAM, trying one stick at a time in each slot then reseating the CPU.
21 minutes ago, AlwaysWright said:should i clear cmos?
Do this first.
4 minutes ago, AlwaysWright said:shit is now bricked
If you have flashback as an option, you can also run it again.
