42 minutes ago, Haswellx86 said:
Please don't upload files. A safer method that I prefer are links to videos.
Does at least normal networking work? Can you browse the web?
YES SIR , I CAN BROWSE THE WEB THIS ONLY HAPPENS WHEN IM CONNECTED TO COLLAGE WIFI , IT WORKS SOMETIMES AND SOMETIMES IT DOESN'T.
jeez, stop the caps.
Can you browse the web correctly on your collage's WiFi? In Task Manager (click on more details) -> Performance tab -> WiFi, what does the IPv4 say? Only report the value when you are connected to that WiFi.
PLEASE MARK COMMENTS AS SOLUTION IF SATISFIED!!
bigger number better, makes me look cooler.
uh ok , well im not at collage right now but ill sent you the collage ip address as soon as i get there ok ?
alr it says 10.10.0.167
