7 minutes ago, rainas said:
Hello, i am planing upgrade my ram, now i have a motherboard that supports 5000mhz only, i am planning to buy 32gb 5200mhz ram, would it cause any issues ? or should i get lower mhz ram?
What motherboard and CPU?
5200 is ddr5 , so get either 6000cl30 for Ryzen or 6400cl32 for Intel.
5200 is the jedec minimum spec.   They'll handle higher.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1585338-ram-speed/#findComment-16544771
4 hours ago, rainas said:
i have i7-13700k, and asus prime b760 plus d4
I'd get these...
https://www.amazon.com/dp/B0BNYWFC91?tag=pcpapi-20&linkCode=ogi&th=1&psc=1
Or if you want RGB< they have a version for that.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1585338-ram-speed/#findComment-16544972
10 hours ago, Dedayog said:
I'd get these...
Pretty sure his board is DDR4.
I would recommend you check your motherboard's QVL on Asus' website & see what kits it lists, then get one of those.  QVLs are less 'reliable' than they used to be, but those kits should at least "work".
Are you planning on getting a 2x16GB kit or a 4x8GB kit? I would recommend 2x16GB if possible, running 4 DIMMs on DDR4 memory controllers can be iffy on AMD & I believe it's still gimpy on Intel as well, in terms of not being able to run speeds as high as you'd expect, or timings as tight as the sticks specify.
Primary Rig:
CPU: AMD 7800X3D @ Stock PBO - Mobo: Gigabyte X670E AORUS Master
2 x 48GB G.Skill Trident Z Royal 6400MHz CL32 1.35V @ 6200MHz CL28-37-32-30 1.5V (still tuning)
CPU Cooler: EK AIO that will be being replaced when I get the chance - PSU: eVGA P2 1200W
GPU: Gigabyte RTX 4090 Gaming OC @ either 2595MHz @ 900mV or 2970MHz @ 1070mV
Case: Thermaltake View 91 - SSDs/HDDs: 1 Samsung 980 Pro 2TB, 2 990 Pro 2TB M.2s, 1 990 Pro 4TB M.2, 1 TeamGroup Cardea Z440 2TB M.2, 1 Seagate EXO X10 10TB HDD
Monitor: Samsung Odyssey G9 49" Super-Ultrawide 240Hz Monitor
https://linustechtips.com/topic/1585338-ram-speed/#findComment-16545284
Good catch
Was focused on the 5200MHz ram being ddr5.
The ddr4 board supports 5k ram?  Or is he confusing the boards?
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1585338-ram-speed/#findComment-16545291
Yeah oddly, according to Asus website, it supports up to
Quote
Memory
4 x DIMM, Max. 128GB, DDR4 5066(OC)/5000(OC)/4800(OC)/4600(OC)/4400(OC)/4266(OC)/4000(OC)/3733(OC)/3600(OC)/3466(OC)/3400(OC)/3333(OC)/3200/3000/2933/2800/2666/2400/2133
So not officially 5200, but I'm betting one could get there with sufficient tuning, as long as the CPU memory controller plays nice.  I haven't had Intel since the 9900K so I can't comment on that.
Primary Rig:
https://linustechtips.com/topic/1585338-ram-speed/#findComment-16546107
I think DDR4 realistically can hit 4400MHz, at least what I have seen from this forum.  I haven't run across anyone breaking more than that.
Get 3200CL16 or 3600CL18 for DDR4.  The higher frequencies are damn near impossible to hit.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1585338-ram-speed/#findComment-16546112
Personally I wouldn't bother paying the premium that the 5200MHz kit probably comes with, get a 4000MHz or 3600MHz kit instead & tune it yourself - even if the prices are similar, it's very unlikely that the 5200MHz is going to actually be a thing that you can run without significant tuning to get it stable.
The kit I had in my 5950X setup, I just looked it up, it was 4x8GB CL15 1.5V 4000MHz, I had it running at 3800MHz (for the 1900 FCLK 1:1) at CL14 with slightly lower voltage than stock and it was happy as a clam.  I imagine the bigger you go on DDR4 kits the harder it is to hit higher speeds, same as it is with DDR5 and DDR3 before it, so expecting to hit 5200MHz on a 32GB DDR4 kit is probably not realistic, even on Intel.
Primary Rig:
https://linustechtips.com/topic/1585338-ram-speed/#findComment-16546746
