Budget (including currency): 1100 EURO
Country: Georgia
Games, programs or workloads that it will be used for:
Other details :
I Have system with these specs:
Processor    Intel(R) Core(TM) i5-10400F CPU @ 2.90GHz, 2901 Mhz, 6 Core(s), 12 Logical Processor(s)
BaseBoard Manufacturer    ASRock   B460M Pro4
Installed Physical Memory (RAM)    16.0 GB
Adapter Description    NVIDIA GeForce RTX 2060 (6 GB)
I really love Gaming and been using this PC of mine for 3 years now but I can see it having some trouble with some of the modern games with maintaining 60 fps sometimes at even mid or high mix settings. I recently got money, around 1100 Euro and wanted to do something and upgrade my pc as much as possible with that budget by adding some new stuff to it ( I definitely also looking for 1 or 2 TB SSD). As much as Love PC, I am not too knowledgeable with parts, at least to know specifics and details to effectively use this budget as best as possible so I would like to ask you guys here some help and advice about which parts can I or Should I by and upgrade my specs with 1100 Euros, thank you for attention!
https://linustechtips.com/topic/1584519-i-need-help-with-upgrading-pc/
Not sure what the full requirements are, but I'd probably consider something like a 7900 GRE and then a full platform upgrade to something like a 7600/B650 board/32GB of memory.
Country: Georgia
Other details :
Honestly, If you want to upgrade to latest gen and stuff, you should just build a new PC. https://de.pcpartpicker.com/list/qht728
7600x and a 7700xt. You can get a 7800xt if you go 50 dollars over budget, but this is good enough.
Make sure to mark solutions, as it helps us find people who need help faster. Thanks!
I am human and am therefore prone to error, so I apologize if I make mistakes and I hope you understand.
Have a Nice Day!
