Should I expect to receive a drive with the same components as reviewed when released? I was considering Adata Legend 960 Max and XPG Gammix S70 Blade, but after reading about XPG SX8200 Pro, I am reluctant to buy. Is it any safer in this respect, to choose a drive even at a higher price, from a NAND flash memory manufacturer such as Samsung and Crucial?
https://linustechtips.com/topic/1584310-ssd-parts-swapping/
i have generally advised avoiding ADATA in general at  this point for drives. Not only have they had a bad reputation for what you mentioned, they are often one of the highest failure rate for SSDs for some reason. Each drive design will be different but man the amount of ADATA drives ive seen fail personally or on other repair shops/youtube channel is no joke.
https://linustechtips.com/topic/1584310-ssd-parts-swapping/#findComment-16536092
so fun fact, crucial, and samsung also swapped components after some time, and well samsung had trouble even without it  (falling 128l nand node in 980, 980 pro, 970 evo, 870 evo, as well as firmware bug that was ruining NAND by rewriting it in 980 pro, and 990 pro)
As for ADATA, unfortunately, the S70 Blade did in fact had already had a component swap, for a china NAND substitute.
if you want to buy one from adata, so far the XPG Gammix S70 Pro, and 960 / 960 max should be ok.
They are identical, on silicon motion SM2264F + DDR4 + 176l TLC micron, no report on components swaps in them so far.
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + Thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + PLX88024 PCIe switch (PCIE 4.0 x8 -> 4 x M.2 PCIe 4.0 x4) -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD : LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + flexiDOCK MB014SP-B + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aiyima A80 ( or Aune S6 Pro -> RCA ->  Aiyima A80 ) -> Polk S20e black -> Monoprice stand 16250
HEADPHONES : PC -> TOSLINK 2m -> Linkfor ULK073 1x4 Digital SPDIF Splitter (B07MJ4TLWQ) -> TOSLINK 0.5m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + Kensington VeriMark / PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Razer Wolverine V3 Tournament Edition 8K PC (B0F94C9C43) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox series x controller pc (1VA-00002) + Ravcore Javelin
NET :  Intel E810-XXVDA2 2 x 25GbE SFP28 (PCIE 4.0 x8) -> 2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3) -> Qnap TS-932X-2G + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB -> 2 x FTLX8571D3BCV-IT -> Noctua NF-P14s redux 1200 PWM -> QNAP TR-004
https://linustechtips.com/topic/1584310-ssd-parts-swapping/#findComment-16536256
  • 2 weeks later...
I don't prefer Adata than Samsung or Crucial, but for example 960 Max compared to 990 Pro is cheaper and from its specifications, it has better TBW and MTBF. But how reliable is it?
https://linustechtips.com/topic/1584310-ssd-parts-swapping/#findComment-16544504
176l TLC micron is a good nand, should do 3000 P/E cycle
EXTERNAL
HDD/SSD :
https://linustechtips.com/topic/1584310-ssd-parts-swapping/#findComment-16544726
So P5 plus vs 960 max?
They are on the same 176l TLC micron nand.
Both are on 8 channels 1600MTps controllers, but 960 max have just little stronger controller with 4 x R8 arm cores,  instead of 1 x R5 + 1 x M3 in p5 plus.
EXTERNAL
HDD/SSD :
https://linustechtips.com/topic/1584310-ssd-parts-swapping/#findComment-16545569
And 960 Max seems to have faster DRAM from Samsung instead of Micron. Is that heatsink really needed?
https://linustechtips.com/topic/1584310-ssd-parts-swapping/#findComment-16545596
Dram speed shouldn't matter.
heatsink will help with any extended usage, as the ssd do get hot.
but that is, if you don't already have heatsink on your mobo.
what’s your use case for the ssd?
For normal use, p5 plus/960 max/990 pro will all be almost indistinguishable.
EXTERNAL
HDD/SSD :
https://linustechtips.com/topic/1584310-ssd-parts-swapping/#findComment-16545830
I am more concerned about endurance, so I could even buy a DRAM-less drive if the price difference is significant. How would for example TEAMGROUP MP44L compare to the above DRAM drives?
https://linustechtips.com/topic/1584310-ssd-parts-swapping/#findComment-16546851
