So I have a 5600 X3D with an ID-COOLING SE-224-XTS cooler (cheap but reviews by Gamers Nexus and Hardware Canucks show good performance). While I'm playing a game, the temp will stabilize around 80 C. I kind of remember seeing something about them running hotter because of the thicker 3D v-cache but is this TOO hot or is it normal? Just want to make sure before I kill my CPU 😅
https://linustechtips.com/topic/1583616-x3d-cpu-temps-normal/
80 is quite hot while gaming, what's the idle temperature? My 7800x3D would run at about 50-55 degrees while gaming with a 280mm radiator.
Is the paste applied correctly? No sticker left under the block? Mounted correctly?
https://linustechtips.com/topic/1583616-x3d-cpu-temps-normal/#findComment-16529896
Yes thats normal. You can try reseating the cooler and check if the whole heatspreader is covered. Alternatively you can try setting a negative offset.
Edit: Read it as full load 80C. 80C in gaming is a little much as @Naijinmentioned.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1583616-x3d-cpu-temps-normal/#findComment-16529897
Idle temp right now is about 41 C (room temp at 66 F) at about 10% usage just with Firefox and qBittorrent. As far as I know the cooler is seated correctly (didn't check the paste spread at first install), def no sticker under the block though, that I did make sure of 😂 I'll remove it and check the paste tomorrow. Max clocks is about 4.32 GHz under load and it draws like 99W (was just doing a Blender Benchmark earlier).
https://linustechtips.com/topic/1583616-x3d-cpu-temps-normal/#findComment-16529913
Thats a lttle high as well, could mean its not well seated. Check if screws of mounting hardware and cooler is tight when replacing thermal paste.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1583616-x3d-cpu-temps-normal/#findComment-16529919
Yeah seems kinda hot though. I'd re-do the mounting, maybe even use a different paste. X3D chips are not very high TDP parts though.
| CPU: Ryzen 7 7800X3D | MOBO: AM5 B650 Aorus Elite AX | RAM: G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | GPU: Sapphire PULSE Radeon RX 7900 XTX | SSD: Samsung 9100 PRO 1TB with heatsink | Cooler: Arctic Liquid Freezer II 360 | PSU: Seasonic Focus GX-850 | Case: Lian Li Lanccool III | Mousepad: Zowie GTF-X  / Vaxee PC / PA / Artisan Raiden Mid XXL| Mouse: Vaxee XE wired / Hitscan Hyperlight | Keyboard: Wooting 80HE zinc alloy raw - geon raw HE switches | Headset: Beyerdynamic MMX 300 (2nd Gen) | Monitor: LG 32GS95UV-B OLED 4K 240Hz / 1080p 480Hz dual-mode | OS: Windows 11 |
https://linustechtips.com/topic/1583616-x3d-cpu-temps-normal/#findComment-16529941
its normal... for a cheap cooler especially.
cheap reviews
yeah, yt =/= reality ¯\_(ツ)_/¯
you can try undervolting with PBO2, that's probably what they did when they got better temps than average.
-Scott Manley, 2021
https://linustechtips.com/topic/1583616-x3d-cpu-temps-normal/#findComment-16529972
Definitely too hot.  Here's my 5600x3d with stock 5600 cooler in a weak case at 72f ambient...
Case and cooler, then idle, then running Ark....
IMG20240925084527.thumb.jpg.d7c5ec8ec99a7b6072ecaad8b00f5ad4.jpgIMG20240925084541.thumb.jpg.92fab5082b4d67000b9659c89fad15c1.jpg
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1583616-x3d-cpu-temps-normal/#findComment-16530124
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1583616-x3d-cpu-temps-normal/#findComment-16530125
So this is what the paste looked like after checking it. I went to MicroCenter and got a Thermal Grizzly PTM pad, temps now stabilize at 77 C playing Apex Legends, 1440p, max settings. I should probably just get a better cooler if I want less temps 😂 pretty sure 77 C won't kill it, right?
https://linustechtips.com/topic/1583616-x3d-cpu-temps-normal/#findComment-16531563
77c is perfectly fine.   Can't cook CPUs anymore anyway 👍
Look at setting PBO/CO in the bios too.
OnePlus Ecosystem:
3D Printing:
https://linustechtips.com/topic/1583616-x3d-cpu-temps-normal/#findComment-16531565
Sorry to bother again but I just got a 5 pack of Arctic P12 fans for my case (I was just running the system without the glass panel on before this and the 2 stock fans that come with the 4000D Airflow case). Got a question about the fans though. They're not PWM, connectors only have 3 pins. Does this mean I can't control the RPMs at all and they just run at the 1800rpm on the spec sheet all the time?
https://linustechtips.com/topic/1583616-x3d-cpu-temps-normal/#findComment-16532388
