Hey, so right now I have a 2 TB Barracuda and a 3 TB WD RED Drive in my PC, before these HDD's i had others and ran into problems losing some of my data, etc. So I don't want to run into that again, so I came up with two solutions.
First Solution: Get another 2 TB Barracuda and another 3 TB WD RED, and run it in RAID 1 with the drives I have.
Second Solution : Get another 2 TB HDD, and another 3 TB HDD and a 2-bay NAS, and manually back up the storage on the ones I have in my computer into them. Every week or so.
I am just trying to find a way where I don't resort in losing data. As I had one my HDD's fail on me and couldn't recover anything and one of them ended up getting corrupted and was a huge pain to recover the data. So, don't want to go through that again.
https://linustechtips.com/topic/158333-which-solution-is-better/
It sucks dude, thats why I built my raid 10 server with nightly backup, double drive protection, and all that then is constantly backing up 24/7 to cloud
I would recommend getting the NAS and have a nightly/weekly backup that way you have a second copy of all your data
https://linustechtips.com/topic/158333-which-solution-is-better/#findComment-2110437
an external storage and manually do a backup or setup a scheduled backup is your best option.
Win 10 Pro 64bit| Intel i5-4670k| Corsair H100i| ASUS Maximus VI GENE| 2x8GB PC3-14900 Corsair Vengeance Pro Red| MSI GeForce GTX 1070 | SanDisk 240GB Extreme Pro SSD| WD 3TB Red | WD Black 3tb | Corsair Obsidian 350D| Corsair AX760 | Dust |
https://linustechtips.com/topic/158333-which-solution-is-better/#findComment-2110690
External storage would probably be your best bet and back up manually. May not be easiest, but definitely safest
Beneath this mask there is more than flesh. Beneath this mask there is an idea, Mr. Creedy, and ideas are bulletproof.
As I get older I get angrier more cynical, meaner. I feel some warning posts coming. I feel a ban coming. I was warned.
CPU-i5 2400 GPU-Sapphire Radeon HD 7970 OC Mobo-H67MA-D2H-B3 Ram-G.Skill Ripjaws 8gb 1333mhz Case-Fractal Define R4 PSU-Corsair CX750 Storage-Samsung EVO 250gb, 1tb WD Black,Hitachi 1tb Other stuff-Corsair K90, M90 Cooling-3x 140mm Fractal fans Sound-Sennheiser HD438 headphones
https://linustechtips.com/topic/158333-which-solution-is-better/#findComment-2110947
