CS2 keep changing audio
Hey! I have a arctis 7 headset and it works perfectly fine in windows and other games but when i play cs2 the audio keeps cutting like its changing audio devices, the headset just disconnects and reconnects.
I tried:
Reinstalling Nvidia drivers
deleted all other audio drivers and devices but my headset
repaired csgo
tried using default and headset in csgo
https://linustechtips.com/topic/1583064-cs2-keep-changing-audio/
I tried:
repaired csgo
Sounds like an issue with your arctis or maybe the use of it. Have you connected both the usb dongle (or whatever the arctis is using) and also bluetooth to the PC? If yes, remove the bluetooth device and only use the dongle. If it's only happening in CS2, set audio device in CS 2 to be arctis instead of default.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
i dont have bluetooth on my pc and this only happens in cs2, i tried using the default and arctis on cs2 settings, no difference.
Try reinstalling the steel series driver
Gaming PC:
Linux PC:
