Problem with Intel Iris Xe Graphics
Go to solution Solved by Eigenvektor,
4 minutes ago, 200anxy said:
yes, i have tried updating to the latest one
I'd try monitoring both RAM and VRAM usage over time. If the issue gets worse over time and is immediately solved by rebooting, it might be a memory leak of sorts. If it is driver related, going back to an older version might also fix it.
Hey there LTT community, i have a problem which i dont know what to fix. My screen randomly starts flickering for some reason, randomly at times. It stops flickering if i stop doing what i was doing (watching youtube) and stop moving my mouse, but it starts flickering like mad when i move anything. It only goes away when I restart. I have tried many fixes, such as installing a new driver, checking the display cable. My computer's specs are: Intel Core i5-1135G7 Intel i5 (with integrated graphics intel iris), 2 Sticks of DDR4 Ram, 512 GB SSD.
https://linustechtips.com/topic/1581665-problem-with-intel-iris-xe-graphics/
First off. Check temps using HWinfo64. After launching the program choose show sensors only.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
3 minutes ago, 200anxy said:
i checked temps, nothing was wrong there...
Looks fine. The only thing I'm wondering about is the bus clock at 90mhz. Normally its 100 or very close to. On my work laptop, running 2x 27 1440p displays:
I would try downloading DDU https://www.wagnardsoft.com/forums/viewtopic.php?t=5016
After run DDU, choose safe mode. After restarting to safe mode, go into options in ddu and mark "prevent windows update from installing drivers". Go back and choose clean and restart after selecting gpu and intel. After reboot, install the newest driver.
Gaming PC:
Linux PC:
Since it's the iGPU, the system memory could be failing.
If a post resolved/answered your question, please consider marking it as the solution. If multiple answers solved your question, mark the best one as answer.
Yes, i think i have found the issue, it is a memory leak of sorts. Thank you
